How to connect wires if I want to add one more heater and thermistor on hot end. March 01, 2017 06:44PM |
Re: How to connect wires if I want to add one more heater and thermistor on hot end. March 02, 2017 03:36AM |
Re: How to connect wires if I want to add one more heater and thermistor on hot end. March 02, 2017 04:24AM |
Re: How to connect wires if I want to add one more heater and thermistor on hot end. March 09, 2017 01:33PM |
Re: How to connect wires if I want to add one more heater and thermistor on hot end. March 09, 2017 04:30PM |
Admin Registered: 13 years ago Posts: 7,000 |
Re: How to connect wires if I want to add one more heater and thermistor on hot end. March 10, 2017 04:55AM |
Dust
For temp control your going to have to lie to your printer and set it up as a second hotend.. no support for second heated bed in any firmware that im aware of.
Dust
I would probably just get a arduino and plug that into the Sevenswitch, set that up as a independent system
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: How to connect wires if I want to add one more heater and thermistor on hot end. March 10, 2017 07:05PM |
Re: How to connect wires if I want to add one more heater and thermistor on hot end. March 11, 2017 05:47AM |
Re: How to connect wires if I want to add one more heater and thermistor on hot end. March 13, 2017 05:36AM |
o_lampe
You'd have to use the Fan output as second extruder heater ( D9 ).
Also #define MOTHERBOARD BOARD_RAMPS_EEB ( #34 ) instead of RAMPS_EFB in Marlins configuration.h.
Then change thermistor definition for T1 to match the new thermistor.
Re: How to connect wires if I want to add one more heater and thermistor on hot end. March 13, 2017 10:41PM |
Re: How to connect wires if I want to add one more heater and thermistor on hot end. March 14, 2017 03:31AM |
frankvdh
A little more information about what you're trying to achieve would be helpful.
It sounds like you want to have two heaters and two thermistors in a single hot-end? What do you want to measure with the second thermistor? How will that differ from the first thermistor? If it's not significantly different, then just use one thermistor to control both heater circuits. But then, why not a single more powerful heater?
Or do you want to have *two* hot-ends each with a heater and thermistor? And presumably two extruders.
