running 34nema motors from ramp 1.4 sprinter pronterface
Posted by timm
April 14, 2017 06:02AM
Hi
Im having trouble getting one motor to spin using arduino and sprinter and pronterface i have the small extruder motor connected and its working ive tried different wiring setups and change the steps in sprinter ****any help would be apprieciated ******here are some pics******* the black motor wire is attched to a yellow motor wire
1 MA860H Stepper Motor Driver Max 80VAC or 110VDC with 2.4-7.2A
1 Dual Shaft Nema 34 CNC Stepper Motor 8.5Nm(1204oz.in) 34HS46-5004D
1 Switching Power Supply 350W 60V 5.9A for CNC Router Kits 115V/230V S-350-60
Stepper Motor 34HS46-5004D
Manufacturer Part Number 34HS46-5004D
Motor Type Bipolar Stepper
Step Angle 1.8°
Holding Torque 8.5Nm(1204oz.in)
Rated Current/phase 5.0A
Phase Resistance 1.0ohms
Recommended Voltage 24-60V
Stepper Driver MA860H
High performance, cost-effective
Supply voltage up to 80VAC or +110VDC
Output current up to 7.2A
Pulse input frequency up to 300 KHz
16 selectable resolutions in decimal and binary, up to 51,200 steps/rev
Suitable for 2-phase and 4-phase motors
MA860H driver
Max.
Unit
Output Current
2.6
7.2(5.1RMS)
A
Supply Voltage
18
60
80
VAC
+24
+80
+110
Model S-350-60
DC Output 60V 5.9A
Adjustable range for DC Voltage 54.5V~67V
AC Input Voltage 93~132V/176~264VAC Slected by Switch
AC Input Current 3.6A/115VAC 1.8A/230VAC
The black wire comming from the driver is attached to the yellow motor wire
I think ive got the wiring right,,,, but not sure about changes in sprinter firmware any help would be appreiciated
open | download - 2smllxxxxx.jpg (136.5 KB)
open | download - 1smll.jpg (94 KB)
open | download - 3smll.jpg (105.2 KB)
Re: running 34nema motors from ramp 1.4 sprinter pronterface
April 14, 2017 01:49PM
What about signal levels? Some external drivers work with enable=high, some with enable=low.
This can usually be changed in firmware. ( IDK sprinter ? )
Does the stepper shaft turn freely when enabled, or does it block?
Edited 1 time(s). Last edit at 04/14/2017 01:50PM by o_lampe.
April 15, 2017 01:04AM
Hi thanks for reply
I change the signal level to high,but still when I pressed connect on pronterface the motor goes clunk and doesnt rotate,then when I press Y axis it goes clunk but doesnt rotate.When power is not on,, shaft can be turn by hand when powered up.. i cant turn motor.
any help appreciated thanks for your help..
April 15, 2017 04:17AM
It seems the stepper coils are energized and enable works.
Now you can try to switch around the wires of ONE coil. Maybe the stepper tries to run CW/CCW between each other step.
With a NEMA17 you can hear them hum then, not sure what a NEMA34 would do. So be prepared winking smiley
April 16, 2017 03:42AM
Thanks for your reply
I changed the Aplus motor wires around nothing changed ,,,so I put them back and change the B minus wires around nothing changed..
Any help would be appreciated
April 16, 2017 09:34AM
Is it red wire on ramps connected to the 5v?
If so, then stepper driver should be wired as common (5v) anode.
The step/direction/enable pins on the Ramps are taken to the GND inputs on the external driver.
April 17, 2017 08:24PM
Thanks for your help
Yes I have the red wire connected to the 5v ramps... I changed over the step/direct/enable wires from ramps to ena-/dir-/step-
heres some pics not sure if thats what you meant.I tried with this setup still no go motor got very hot..
open | download - ramps sml.jpg (118.9 KB)
open | download - driver pwr sml.jpg (245.2 KB)
April 18, 2017 02:05PM
Set the current to ≈75% of your motor's rated current.
Reducing the microstepping e.g. 16x for a testing purpose.
open | download - ramps_20.jpg (152.6 KB)
April 18, 2017 06:02PM
On the Ramps the 5v pin you are using does not have 5v on it
That connector the top pin vcc has 5v.
That connector is normally used to make the 5v pins on the servo connectors live by putting a jumper from vcc to the 5v pin
Edited 1 time(s). Last edit at 04/18/2017 06:44PM by Dust.
April 22, 2017 05:02AM
Thanks so much for your help
I tried your common anode setup.. still running sprinter firmware,,, nothing happened... then i tried reptier firmware and the motor turns CW when i hit pronterface CW and CCW when I hit CCw button...happy days thank you The homing button makes the motor turn too ....My next issue is to speed up rotation ive tried to change config firmware with no results ...Ive also tried to hookup end stops and config with no results....
any help would be appreciated
April 22, 2017 07:25AM
use command line gcode g1 with parameter f feedrate
f is in mm/min
eg g1 x50 f6000
move x by 50 (or to 50 is absolute mode) at 100mm/s (* by 60 for mm/min)
This of course depends on your steps/mm values being correct
Also be ware of max feed rate value in firmware. These will clip at that value.
Edited 1 time(s). Last edit at 04/22/2017 07:30AM by Dust.
April 25, 2017 09:45PM
Yes can speed up axis with gcode..
My next question is.... Ive plug in one of my end stops x... when I press the homing button it wont stop when I press the x end stop?.. just testing electrics..
..Im also getting this error ...... is this because I dont have any hot end or heat bed connected.
Printer is now online.
Free RAM:2671
X:0.00 Y:0.00 Z:0.000 E:0.0000
heated bed: temp sensor defect
Errortongue sticking out smileyrinter set into dry run mode until restart!
[ERROR] Errortongue sticking out smileyrinter set into dry run mode until restart!
ok 0
ok 0
ok 0
ok 0
Any help would be greatly appreciated
April 26, 2017 12:38AM
"heated bed: temp sensor defect"
Its not reading room temp on the bed and panicking
check endstops are working with M119 command, ie send M119, then hold endstop and send M119 again, does the endstop you expect to be triggered now say triggered?
