Why 16V polyfuse?
Posted by Aethelstan
Why 16V polyfuse?
May 28, 2017 10:50AM
I am in the process of upgrading my printer to run on 24V, but I have a question regarding the 16V, 11A polyfuse. Why is it rated at 16V? I can't see there ever being anything near 16V dropping across the fuse as it should be conducting with very low resistance. Using the datasheet specifications, when conducting 11A of current with a maximum resistance of 0.0089 ohms, that's only 0.09V dropped by the fuse. Using a 24V bed wouldn't draw that much current anyway. I understand that I need to change it, especially having read the reports on here about them catching fire and I will remove it and use a real fuse in it's place. I would just like to understand why.
Thanks smiling smiley
Re: Why 16V polyfuse?
June 10, 2017 03:31AM
I think that the problem is when you have a short: Then you will have the full 24V over the fuse, and that's when it gets dangerous and the fuse can catch fire before it traps.
June 10, 2017 09:58AM
enif
Exactly.
Delta printer calibration calculator, mini IR Z probe, and colour touch screen control panel: [escher3d.com]
Large delta printer, and other 3D printer blog postings: [miscsolutions.wordpress.com]
Disclosure: I have a financial interest in sales of the Panel Due, Mini IR height sensor, and Duet WiFi/Duet Ethernet.
June 30, 2017 10:37AM
Cheers, I am still learning this stuff so I am very grateful for your replies. I need to start thinking about what happens in fail states smiling smiley
