RAMPS 1.4 to big drives
Posted by ka67_72
June 25, 2017 03:27PM
I have an older home built gantry machine that hasn't been used in years. I would like to use it for large format 3dp. I used to run Mach3 but would like to use a RAMPS board to control it now. Would it be possible to get step and direction from the RAMPS to this Rutex Servo Drive ? Pin out starts on page 5.
Thanks,
Kevin
VDX
Re: RAMPS 1.4 to big drives
June 25, 2017 04:38PM
Hi Kevin,
check, if the STEP+DIR inputs are defined for +5V ...
Viktor
June 25, 2017 04:44PM
The drives are meant to be run off a pc printer port. The way I understand it they get +5 to the pulse and dir pins.
Thanks,
Kevin
Edited 1 time(s). Last edit at 06/25/2017 10:19PM by ka67_72.
VDX
June 26, 2017 02:12AM
... so shouldn't be a problem winking smiley
Viktor
June 26, 2017 02:16PM
I think I figured it out. I tried hooking to the drives Sat and got no result. I checked for a pulse with my graphing multimeter but dc wasn't working so I wasn't confident in the voltage readings. I brought ut to work and hooked to a scope. I was only getting 50mV with usb power. I gave it 12 volts and now I get nice 5V squares.
