RAMPS 1.4 Wierid bed temperature behaivour.
Posted by BortEngineer
June 29, 2017 04:59AM
I have RAMPS 1.4/MEGA 2560 machine, which worked flawlessly for almost 6 years until today. I powered it up today and instead of expected "3D printer ready" message i've got "ERR: MAXTEMP_BED".
So I've started diagnostics. First thing i did is thermistor check: both extruder's and bed showed around 115k resistance with room temperature of 20 degrees celcius.
I've checked this values on the board side connectors, with this values i can assume that wiring and termistors are fine.
Then I've pull arduino off and test analog pins responsible for temperature readings(A13-A15) with this simple sketch:
int a = 0;
int b = 0;
int c = 0;
void setup() {
  Serial.begin(9600);
void loop() {
  delay(500);
  a = analogRead(13);
  b = analogRead(14);
  c = analogRead(15);
  Serial.print("A13: ");
  Serial.print(a);
  Serial.print("; ");
  Serial.print("A14: ");
  Serial.print(b);
  Serial.print("; ");
  Serial.print("A15: ");
  Serial.println(c);
Plugging all 3 pins on different external voltage sources shows that's arduino is ok(readings from pins are ~0 for GND, ~690 for 3.3 volts and ~1020 for 5 volts).
Moving to RAMPS board: all three thermistor inputs has correct pull up resistanse of 4.7k on the one side and straight path to the ground on the other side.
One diference i have found is the voltage on the thermistors itself. On T0 which is still intact, voltage is 5v no matter what thermistor is plugged in, on the T1 and T2 there is 0.5v in all cases tested(yes, tried to remap bed to another pin with no luck).
Is there any quick fix for that issue or it would be simplier to buy new RAMPS board?
Re: RAMPS 1.4 Wierid bed temperature behaivour.
June 29, 2017 06:38AM
poss leaky caps C8, C1. these are connected across the thermistors
open | download - RAMPS1.4schematic.png (444.2 KB)
July 02, 2017 04:39AM
Unsoldered one of 'failed' capacitors and tested it, it's should be fine.
Any suggestions?
Edited 1 time(s). Last edit at 07/02/2017 04:42AM by BortEngineer.
open | download - IMG_20170702_112911~01~01.jpg (569.4 KB)
July 02, 2017 06:25AM
Nevermind, i found the issue. Rewinding all stuff that were done, I've came to conclusion that I have toasted A14 and A15(somehow confused smiley) on Arduino when i was cleaning heatbed from hairspray residue with razor blade, shorted 12 volts to thermistor terminals, which altered input impedance on that inputs.
To fix this i unsoldered A14 pin and add wire to A10 pin on AUX2 port, and remapped heatbed thermistor in pins_RAMPS_14.h corresponding to new wiring.
Edited 1 time(s). Last edit at 07/02/2017 06:28AM by BortEngineer.
April 12, 2018 09:48AM
I encountered a similar situation, even though I tried replacing my Arduino board. However, I still get similar readings from T1 and Bed (0.5V) and 5V from T0.
I will try your solution! I understand that you reconfigure Bed to A10 in pin_Ramps.h, correct?
Thanks
Berthold
April 12, 2018 12:10PM
Yes, but firstly i suggest to check your wiring for issues, my issue was 12v on arduino analog pin.
I've redefined pins in pins_RAMPS_14.h, in particular,
#define TEMP_1_PIN         11   // ANALOG NUMBERING -- WAS 15 -- IT'S TOASTED ON MY MACHINE
#define TEMP_BED_PIN         10   // ANALOG NUMBERING -- WAS 14 -- IT'S TOASTED ON MY MACHINE
You can choose pins on your own, just make sure it would not overlap something important already in use.
(Note: this is Marlin 1.1.0 FW)
