Motors necessary for a cubic meter printer based off D-bot
Posted by rodrigo
July 04, 2017 03:33AM
Hi everyone,
I am building a 1 cubic meter (1x1x1m) printer for research purposes WITHOUT an extruder and heated bed. Basically I am building a gantry with XYZ movement and an acrylic bed.
The plate moves up to 50 kg up and down with 4 lead screws powered by one (or two if necessary) NEMA 23 motor with a large timing belt around them in a rectangular shape with the motor's pulley attached straight to it (simplicity is of utmost importance). An aluminum frame is moved in the x axis via 2 motors and in the Y direction with one motor mounted on this same frame.
I have come across the D-bot electrical diagram here cdn.thingiverse.com/assets/15/31/5e/8b/3c/D-Bot_Electrical_Diagram.pdf and would like to modify it for simplicity without the heating elements and LED strip.
Basically the questions are, how do I modify the diagram (do I just remove the components I won't be needing?)? Do I still need a relay if I won't use a heating bed? Do I need to change anything other than the PSU to use these more powerful motors (NEMA 23 345 Oz.)?
Thanks for helping! As a mechanical engineer, my electronics knowledge is somewhat impaired.
Hopefully I can get a reply soon, I need to order the components tomorrow (I got this research opportunity just a few days ago smileys with beer )
Edited 1 time(s). Last edit at 07/04/2017 04:13AM by rodrigo.
open | download - Mammoth.PNG (596.2 KB)
Re: Motors necessary for a cubic meter printer based off D-bot
July 04, 2017 04:22AM
Ok it seems I'm basically building a CNC milling kit for 3D printer use (it will eventually have some extruder, just not a melting one) so I came across this amberspyglass.co.uk/wiki/EShapeoko_Complete_Kit however, it does not use RAMPS and I do need the functionality of RAMPS later on. How could I adapt that one to my design?
July 04, 2017 05:17AM
this controller is basically the same as a ramps, minus the mosfet and thermistors, probably running grbl firmware (processor is a Atmel Atmega 328p vs a Atmel Atmega 2560, ie 2560 has more ram and rom)
To convert all you need to do is wire the steppers to some ramps type plugs and plug into a ramps with what ever firmware you want. even can use the same driver modules.
Edited 1 time(s). Last edit at 07/04/2017 05:19AM by Dust.
July 04, 2017 05:27AM
re larger steppers
You have to use stepper that can be driven by standard pololu modules (Pololu A4988, or Pololu DRV8825)
for anything larger, you have to use external stepper drivers, anything that uses the standard step,direction and enable can probably be used.. You simply remove the driver modules and use the step/dir and enable lines. (some external stepper drivers do require you to change the pulse width, as they can't respond to such quick pulses)
ie something like
NB this image contains an error, the +5v line needs to be plugged into vcc not +5v on that 3 pin connector
Edited 3 time(s). Last edit at 07/04/2017 05:33AM by Dust.
July 04, 2017 09:42AM
Thanks a lot Dirt!
So I started checking the TB5650 drivers and they would be able to handle the 3A NEMAs.
If I understand right, there is nothing else that needs to be changed right? I just plug them to the ports where the Pololu drivers would have been.
Also, are they also good for 1.5A NEMA 17s? I decided for now to use those for the XY movement but still have the chance to later upgrade if necessary.
I will soon upload a fritzing diagram hoping it is correct.
July 04, 2017 04:31PM
IMO, Arduino/RAMPS is a reasonable choice for small budget printers. But to get a good print quality from a printer with 1m^3 print volume you will have to spend a lot of money, and it doesn't make sense to use budget electronics in such systems. There are alternative (ore expensive) electronics solutions that will drive Nema 23 motors without having to use external drivers, and with additional benefits.
Delta printer calibration calculator, mini IR Z probe, and colour touch screen control panel: [escher3d.com]
Large delta printer, and other 3D printer blog postings: [miscsolutions.wordpress.com]
Disclosure: I have a financial interest in sales of the Panel Due, Mini IR height sensor, and Duet WiFi/Duet Ethernet.
July 05, 2017 01:49AM
24V for NEMA23 is the bare minimum voltage. Don't know, how fast you want to lift the bed, but they'd sure like to run on 36-60V driver modules.
July 05, 2017 03:43AM
Hmm ok then, I guess I can use 24V power. This is a project for my university so more expensive parts would also be ok, however one of the goals is to try and manage it as cheaply as possible to study the feasibility of building such a printer on a tighter budget. So far the only "crazy" requirements are lifting 50 kg (which is not even that much considering the Gigabot we have here has a 60x60x.7cm aluminum printer bed) and the size, but other than that I am basically moving lightweight rollers across a longer distance which can be easily achieved with NEMA 17s even.
I have also decided to use 2 NEMA 23s to lift the bed just to make sure. As you can see, the requirements are not that high, I just have longer travel distances.
July 05, 2017 04:23AM
So there are no RAMPS or TB6560 modules in fritzing, but basically I will use the diagram given by Dots to wire the motors, the first diagram I linked for wiring the endstops and fan, and this [reprappro.com] for wiring the second X movement motor.
Only one question remains, how do i know if my components are 24V compatible and how do >I make the change from 12V to 24V?
July 05, 2017 09:52AM
You can run a RAMPS with 12V max. without hacking a few things. The Nema17 are OK with 12V and for the two Nema23 you can use a small DC-DC boost converter to feed the external drivers. That's cheaper than two power supplies.
July 05, 2017 10:21AM
I'm actually using a Taurino Power with a RAMPS Premium and they should be able to handle 24V [ooznest.co.uk] . I am ordering also a 24V 350W PSU [ooznest.co.uk] which I am not totally sure is necessary as I don't know what the rated voltage VDC/phase means (the NEMA 23s are 3.6V 3A and the 17s are 1.68A).
July 05, 2017 05:48PM
Taurino Power does indeed handle 24v as designed
August 22, 2017 12:44PM
Hello, so given what has been said before, would a 24 VDC psu be sufficient for a Nema23 stepper such as the one attached?
If not, what are the options if one wants to use Nema23 steppers powered at 36V? Would the Taurino Power + Ramps Premium or the RUMBA board be the only 2 options or is there a simple way to make this work with a MegatronicsV3 or a Arduino Due + RADDS shield for example?
open | download - Nema23_19.1kg.cm_3.2V_2.8A.jpg (610.3 KB)
August 22, 2017 05:37PM
The voltage you need to drive stepper motors depends on the speed you want to run them at. Even 6V would be enough to drive those motors at low speeds. To calculate the supply voltage required, see [duet3d.com].
If you calculate that 24V is enough, then a Duet WiFi or Duet Ethernet would be a good match for those 2.8A Nema 23 motors without needing external drivers.
Edited 1 time(s). Last edit at 08/22/2017 05:38PM by dc42.
August 23, 2017 06:34AM
Thank you for the link, I'll make the necessary calculations smiling smiley
How easy is it to set up external stepper drivers to these boards? What if I wanted to use an integrated stepper such as this one: Integratedsteppeonline
Edited 1 time(s). Last edit at 08/23/2017 08:45AM by yala.
August 23, 2017 11:31AM
yala
It's straightforward to connect up to 7 external stepper drivers if they accept 3.3V control signals. Most stepper driver modules do even if they are advertised as 5V (perhaps because 5V TTL-level signals don't guarantee more than 2.4V anyway). You still get to keep the 5 built-in drivers.
That integrated stepper motor you linked to accepts STEP/DIR signals (the web page calls it PUL/DIR), so it should be compatible.
Edited 2 time(s). Last edit at 08/23/2017 11:33AM by dc42.
August 23, 2017 03:29PM
OK thank you great. What if I want closed loop steppers or hybrid servomotor with a built-in encoder?? Like this one: Closed-Loop-Stepper_Stepperonline.com
Is it possible to incorporate this on a Duet Wifi/Ethernet? that would be fantastic
August 24, 2017 02:14AM
The webpage says it has "Isolated control inputs of Pulse, Direction and Enable". So it is compatible. At worst you might have to level shift the signals to 5V, but probably not.
August 24, 2017 05:18AM
Yes it does say that they accept 5V to 24V command signals, so I guess it would be necessary to shift the signal to 5V.
What about the position PEND and alarm ALM signals ? These are not usually present in a normal open loop stepper so how would they fit the Duet stepper driver ports?
(sorry for the dumb questions and thank you for your patience)
August 24, 2017 01:48PM
Unfortunately the link to the manual for that motor doesn't work, so I can only guess at what the PEND and ALM signals are for. At a guess, ALM is an alarm output that signals that something is wrong. If so then it could be connected to a spare endstop input on the Duet which can trigger a user defined macro file, for example to pause the print.
August 29, 2017 10:58AM
Hello again guys,
So I finally got quite far with the printer and most components have arrived.
Right now I have the gantry built and am testing the motors but I have two issues as of now.
First, the steppers heat up quite a lot and really fast (maybe 60 degrees in 5 seconds) and I suspect it might have to do with the PSU being 24V. I adjusted the stepper current knobs beforehand to be half the rated current of the motors (around .84) and i have 2 in series for Y and Z; X only has one.
The second thing I am worried about is a super-high pitched sound coming from the Y-motors after I move them a few centimeters. It is not too loud but it is annoying and worrisome. It is also annoying that no one other than me here can hear it due to it being such a high frequency.
It seems there are a ton of problems arising from endstop settings in Marlin, but would this be the reason why?
