dual extruders on Ramps 1.4, only E0 is working.
August 10, 2017 09:36AM
Hi
Have 2 extruders connected to my Ramps 1.4. Only that one on E0 is working. If I shift the Cables extruder 2 works when connected to E0.
I have replaced the stepper drivers without any luck..
I have the same configuration on both extruders made in Repetier configurator 0,92.
I use M302 S1 for Cold extrusion.
Is there someone with a solution for this?
Is there any jumpers or settings that I HAVE missed?
I can se both extruders, heaters and temp sensor working in Repetier Host.
I have attecded the full software.
BR
open | download - Repetier-Firmware-2017-08-10.zip (433 KB)
Re: dual extruders on Ramps 1.4, only E0 is working.
August 10, 2017 03:35PM
Your config look ok,cant see any errors.
What command are you using to select 2nd extruder ?
August 10, 2017 03:36PM
Hi
Found the problem, error in the MB. Tested with a new one and now it is working.
BR
Problem with dual extruders on Cura/Repetier
August 18, 2017 01:37PM
Hi
I have an CoreXY with Chamira dual extruder.
I want to be able to run different temperatures on the nozzles. I cannot se how to do it in Cura nor in Slice3r for Repetier Host.
Anyone know how to solve this?
BR
Edited 1 time(s). Last edit at 08/18/2017 01:38PM by hokanp.
September 21, 2017 08:23AM
As I am encountering the same issue today, let me resume this thread.
In my case, all steppers work and when I swapped pins between E0 and E1 in the Marlin, the stepper connected to the pins corresponding to E0 now considered as that of E1 did not work whereas the stepper now considered E0 did work. Then, the pins of my RAMPS are working.
I prevent cold extrusion error with M302 or by heating.
Temp sensors and hotends are working just fine.
I'm using Marlin Configuration EEF with a Ramps 1.4 & Arduino Mega.
I'll take any suggestion as I tried almost everything I could to no avail. Just in case, find attached my configuration.
open | download - Configuration.h (54.9 KB)
