RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) September 14, 2017 02:31PM |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) September 14, 2017 04:35PM |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) September 15, 2017 02:02AM |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) September 15, 2017 02:46AM |
o_lampe
Which Marlin version will you run on the Due? Marlin4Due seemed to be in hibernation mode for a while...
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) September 15, 2017 02:52AM |
dc42
Just a couple of warnings/suggestions:
- I'm fairly sure that the Arduino Due can't support the HSMCI interface to the SD card, it only supports the much slower SPI interface. Without HSMCI you won't get high-speed upload to the SD card over the network.
- I looked at the ENC28J60 when designing the Duet Ethernet and rejected it due to insufficient buffer memory to achieve satisfactory performance. We went with the W5500 instead.
I guess you can ignore these issues if you don't care about fast gcode file uploading to the SD card; but most Duet users care a great deal about upload speed because they don't use a USB connection, just a network connection.
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) September 15, 2017 04:01AM |
Admin Registered: 13 years ago Posts: 7,001 |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) September 15, 2017 04:08AM |
dc42
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) September 15, 2017 04:51AM |
Dust
dc42
According to [www.testcor.ca]
All the HSMCI pins are mapped and broken out... so if there is an issue its software...
I also see libraries eg [github.com]
(no idea if it works though)
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) September 15, 2017 06:01AM |
Dust
If you do go Due, you might also want to look at SMART_RAMPS
It already exists.. or just for info...
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) September 15, 2017 06:42AM |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) September 15, 2017 07:57AM |
Dust
While you at it, please route D7 somewhere, it bugs me that its just abandoned on ramps
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) September 15, 2017 09:48AM |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) September 17, 2017 06:57AM |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) September 17, 2017 12:39PM |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) September 17, 2017 04:00PM |
o_lampe
Just to put more pressure on you: You could save a lot of MOSFET terminal space by providing one big common terminal for V+.
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) September 17, 2017 07:43PM |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) September 17, 2017 07:53PM |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) September 17, 2017 08:48PM |
lkcl
i'd also really like to have dual 2560 and Due compatibility, as there will be some people who significantly want to save cost.
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) September 18, 2017 12:55AM |
Dust
since you have moved d1 out from under the pololu, how about replacing it with a 7809 TO-220 package
would make it much easier to run the ramps on 24v and would reduce the load on the mega/due voltage regulator
Presuming its still going to vin...
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) September 18, 2017 01:05AM |
frankvdh
lkcl
Don't bother.... People who care about the $6 difference in cost between a Due and a 2560 won't buy your board anyway... they'll buy a Mega and a RAMPS 1.4.
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) September 18, 2017 04:20AM |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) September 19, 2017 02:17AM |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) September 19, 2017 03:52AM |
Dust
Just been reading your post to the wiki.
"Removed MAX Endstops" and "Removed all AUX except I2C, AUX4 (for LCD) and AUX3 (for SPI-Ethernet) "
this could be an issue for anyone wanting delta machines, that have a endstop per axis stepper and a probe/endstop
This would normally be on all the MAX endstops with the probe on Z-min (the problem is they need 4 inputs, doesn't really matter where or what you call them)
I also think renaming Z1 and Z2 to E1 and E2 would have more appeal (yea I know it makes no electronic difference, but the sheeple wont know this)
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) September 19, 2017 06:39AM |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) September 19, 2017 06:47AM |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) September 19, 2017 07:00AM |
o_lampe
You wanted 6 stepper ports for 3 z-steppers. Don't they need an endstop each ( for bed leveling)?
Also CoreXYU seems to require 4 endstops.
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) September 19, 2017 07:30AM |
Dust
The standard lcd connector ties up all pins on aux-4 but I suspect not all 16 IO pin are in use.. you may be able to break out a few
a quick google later
so yea 5 wasted IO lines when used on standard 20x4 and 128x64 lcds, any others to worry about? viki perhaps, no idea what it needs
Needs to be confirmed...
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) September 19, 2017 02:34PM |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) September 20, 2017 08:23AM |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) September 20, 2017 11:57AM |
