Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 06, 2017 01:08AM |
Dust
I also wonder if you can get SMD .1" connector strips... that would remove a bunch of holes
Oh you can (not really surprising)
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 06, 2017 01:10AM |
JustSumGuy
I am going to lurk out here for a while... learning lots and have little to input
thanx for letting me shoot some input tho
I think I want one of these when it gets a little more traction....
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 06, 2017 01:23PM |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 07, 2017 04:34AM |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 07, 2017 04:54AM |
Admin Registered: 13 years ago Posts: 6,995 |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 07, 2017 05:39AM |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 07, 2017 01:05PM |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 08, 2017 01:56AM |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 08, 2017 03:39AM |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 08, 2017 03:57AM |
dc42
If the Due is only supplying 2.95v output, then I suspect that either it is getting less than 3.3V supply, or you have a pulldown resistor with a rather low value connected to the output.
A 74HCT chip is good to use as a level shifter to 5V.
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 08, 2017 08:31PM |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 09, 2017 09:01PM |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 09, 2017 10:33PM |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 10, 2017 12:13AM |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 10, 2017 12:31AM |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 10, 2017 12:52AM |
dc42
The 0.9V output low voltage of the Mega is probably quoted when the output is sinking a lot of current. It will be much closer to 0V when it is lightly loaded. AFAIR there are output voltage vs. sink current charts in the datasheet, and although they show typical rather than worst-case values, they should confirm this.
However, ground noise generated by the stepper motors may be a bigger problem if you are not careful with PCB layout and routing.
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 10, 2017 01:32AM |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 10, 2017 03:57AM |
o_lampe
..neverending story. I feel for you
I hope the new chosen chip fits all the other needs too, like latency. But I'm sure it's quick enough.
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 10, 2017 11:52AM |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 10, 2017 05:00PM |
obelisk79
My latest project has me swapping crystals on my MEGA2560 to get a little um oomph compared to the arduino reference design since the chips run 20% slower than what they are rated at.
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 10, 2017 07:26PM |
dc42
obelisk79
The rated frequency of the 2560 is only 16MHz. It's the smaller members of the ATMEGA family (e.g. the 328) that are rated at 20MHz.
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 10, 2017 08:08PM |
obelisk79
I've found it interesting to follow the development. Like I said, once the design is relatively stable I'll be interesting in trying one out. My latest project has me swapping crystals on my MEGA2560 to get a little um oomph compared to the arduino reference design since the chips run 20% slower than what they are rated at.
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 10, 2017 08:40PM |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 10, 2017 10:55PM |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 11, 2017 02:24AM |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 11, 2017 02:42AM |
dc42
The Duet WiFi design includes provision for that 10A inductor, but on production PCBs it is bypassed and not fitted.
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 11, 2017 03:30AM |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 11, 2017 05:00AM |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 11, 2017 05:05AM |
Re: RAMPS 1.4.2 fork: RD3D v1.0 (6 steppers, 24v, Due) October 11, 2017 11:48AM |
