X-Stop issues - RAMPS1.4
Posted by LiamGriever
November 11, 2017 10:46AM
I am having issues ever since i installed an inductive sensor on my board. Everything seems to work fine, apart from my X STOP.
Below is the report from M119, keep in mine, i am not touching, or going near my X STOP trigger. I have replaced the trigger switch, i have made sure all connections are good and seated, i have ensured everything is fixed down properly.
Reporting endstop status
x_min: TRIGGERED
y_min: open
z_min: open
>>> M119
SENDING:M119
x_min: TRIGGERED
y_min: open
z_min: open
>>> M119
SENDING:M119
x_min: TRIGGERED
y_min: open
z_min: open
>>> M119
SENDING:M119
x_min: open
y_min: open
z_min: open
>>> M119
SENDING:M119
x_min: TRIGGERED
y_min: open
z_min: open
>>> M119
SENDING:M119
x_min: open
y_min: open
z_min: open
>>> M119
SENDING:M119
x_min: TRIGGERED
y_min: open
z_min: open
>>> M119
SENDING:M119
x_min: open
y_min: open
z_min: open
>>> M119
SENDING:M119
x_min: TRIGGERED
y_min: open
z_min: open
>>> M119
SENDING:M119
x_min: TRIGGERED
y_min: open
z_min: open
>>> M119
SENDING:M119
x_min: TRIGGERED
y_min: open
z_min: open
>>> M119
SENDING:M119
x_min: TRIGGERED
y_min: open
z_min: open
>>> M119
SENDING:M119
x_min: open
y_min: open
z_min: open
Please please someone help!
Re: X-Stop issues - RAMPS1.4
November 11, 2017 01:41PM
Update. M119 reports triggered even when the X stop is unplugged from the board.
November 11, 2017 06:33PM
Most endstops are configured so that when they are unplugged they are triggered. How else would you know your endstop has been unplugged?
November 15, 2017 12:28PM
Dust
While relevant, this isn't exactly helpful. I'm thinking there is something wrong with the pins on the board. Is there a way to reconfigure the code so i can use different unused pins somewhere for my X trigger?
After more investigation, my Y-stop is now always open... As is my Z-stop
Edited 2 time(s). Last edit at 11/15/2017 01:10PM by LiamGriever.
November 15, 2017 03:23PM
you need to edit the pins.h or specific board pins.h to move the endstops to a new pin. Any unused digital IO line can be used
November 21, 2017 06:46AM
Dust
Do you have a guide, or can you run me through how to do this?
November 21, 2017 06:03PM
you haven't told us what firmware you are running
eg If a recent version of marlin
edit pins_RAMPS.h
In it you will find
#define X_MIN_PIN           3
#ifndef X_MAX_PIN
  #define X_MAX_PIN         2
#endif
#define Y_MIN_PIN          14
#define Y_MAX_PIN          15
#define Z_MIN_PIN          18
#define Z_MAX_PIN          19
Change the number to what ever pins you want (Use D(igital) pin names)
See the following image for a list of all pins
Edited 2 time(s). Last edit at 11/21/2017 06:08PM by Dust.
December 05, 2017 02:30PM
I purchased a new ramps board, same issue. I moved the Z-min to D11 which triggered correctly on the Z, but I'm still having the same issue. Please, someone must have a solution here?!
December 05, 2017 05:26PM
Perhaps you don't have the pullup resistors on the endstop pins enabled in the firmware?
Delta printer calibration calculator, mini IR Z probe, and colour touch screen control panel: [escher3d.com]
Large delta printer, and other 3D printer blog postings: [miscsolutions.wordpress.com]
Disclosure: I have a financial interest in sales of the Panel Due, Mini IR height sensor, and Duet WiFi/Duet Ethernet.
