Can not collect temperature, the motor does not move?
Posted by lx1217
December 02, 2017 04:41PM
LCD display temperature of -14 °, 10K resistance test shows 60 °. Test motor lock does not rotate. Test D9 fan 100% speed is very slow. the new ramps did not change, is it 2560 damaged?
Re: Can not collect temperature, the motor does not move?
December 03, 2017 03:49AM
The thermistor seems to be broken. That is a pretty common problem: the legs of the thermistor are very thin and brake off easily.
To test the motors, RAMPS and Atmega2560 you can flash Rampstest and see if all hardware works.
If you want to test it with Marlin, you have to "home" the printer first or use G92 X... Y... Z... to fake homing without endstops.
Then you can test X,Y,Z steppers but Extruder still won't run until you allow cold extrusion
Edited 1 time(s). Last edit at 12/03/2017 03:53AM by o_lampe.
open | download - _Ramps_test.ino (3.2 KB)
December 03, 2017 06:14AM
thank you for your help! ! Tested thermistor is intact, and purchased a new set of accessories, suspected mega2560 circuit failure. . .
