Noise from Y motor on CoreXY
Posted by kendler
December 14, 2017 04:14PM
I've built a CoreXY printer (HyperCube) a few months ago
Not sure why, I've always had a very loud noise when moving, caused by the Y motor vibrating and thus vibrating the entire frame
I've tested a different Motor/Drive/RAMPs board - result is the same. motor is vibrating (can feel it when the motor is in my hand)
Same with Marlin 1.1.4/5/6
Any ideas what can be the cause of that?
Re: Noise from Y motor on CoreXY
December 15, 2017 04:17AM
Just for fun you could define a different printer type and see, if it's a firmware problem with CoreXY kinematics.
December 15, 2017 04:46AM
Good idea.
I've tried. same story - Y motor is noisy
February 03, 2018 05:43PM
Did you check the voltage? Should be around .650 vdc
