24 Volt heated bed on a 12v system
Posted by hokanp
December 26, 2017 09:49AM
Hi
I have a CoreXY printer 300*300mm. My heated bed runs on 12volt (or 24V) and it take a long time for it to reach temperature.
Is it possible to use a 24volt PSU for the heated bed and some sort of relay between the PSU and the connector on the Ramps?
All the rest of the elektronics in running on 12 volt.
Thank you
Re: 24 Volt heated bed on a 12v system
December 26, 2017 06:43PM
Use and external mosfet...
eg [www.aliexpress.com]
plugs into your normal bed output and it switches 24v on/off
Dont use a relay, the clicking will drive you insane (and the arcing will eventually weld the contacts shut)
December 27, 2017 03:34AM
When the heater is for 12V and 24V you won't see a big difference in heating up. You could try to raise the output of your 12V PSU to 14V to reduce heating time.
( If the rest of your electronics can handle 14V too )
I bought a cheap 600W DC-DC-boost converter to increase 24V to 28V because Duet boards are rated up to 25V only. That was a major difference. OTOH you can only use bang-bang heating mode, but my bed temp still is within 0.2°C.
