If the bed has no continuity its broken... Since its a heater, you cant easily repair it as the repair would have to survive the repeated heating and cooling ...
Check its not just the wires... (you didn't say exactly what you tested)
Any damage to the bed could cause a weak spot that would excessively heat up and fail at that point.
One common cause is people mounting the bed on bits of metal that damage the board...
