ramps 1.6 + servos ?
Posted by davidmarli
April 19, 2018 01:52AM
I just bought a ramps 1.6. It seems great, but when I plug my bltouch in servo, nothing lights on...
With my multimeter, there is no 12v between + and - but 0v...
So is there something to do to have power on servos ?
I see 2 pins with no connectors J4 (betwwen the two green connector) is that the solution ?
I find nothing about this ramps 1.6
Thank a lot.
Re: ramps 1.6 + servos ?
April 19, 2018 04:56AM
Servos can be very power hungry, that's why they can be fed from an external 5V source instead of the weak internal 5V reulator. This is usually selectable by a jumper ( which seems to be missing in your case )
BTW: I've never heard of RAMPS1.6, would be nice to add some more info...
April 19, 2018 05:25AM
ramps 1.6 is not open source... so no documentation.. (Shakes fist at manufacturer!!)
On a normal ramps there is no voltage on the +5v pins of the servo lines until it gets jumpered to vcc
most servos are not 12v... so I would be careful trying to get 12v there...
The image I see does show a track going from the +v line to somewhere.. but cant see where...
April 19, 2018 05:28AM
@o_lampe
Its a bigtreetech only board.
violates gpl, no documentation
avoid at all costs
