I can't get part cooler fan to work.MKS GEN L V1.1 / Marlin
Posted by Tryit
May 17, 2018 03:43PM
Hello my first post here so be gentle!
I have built a FLSun I3 plus and, with some modifications, it works OK. I added a part cooling fan and plugged it in to the "Fan" / "D9" socket (= arduino D9 pin) and try as I might I can't get the fan to move.
I have tried:
Another fan.
changing this line in marlin/Configuration_adv.h
#define FANMUX0_PIN 9
Any ideas?
I am assuming using the touchscreen controller to set the fan to a non zero speed should work anytime. I have printed a PLA object to test too.
FYI:
The supplied hardware loaded with recent Marlin and configuration seems OK apart from this issue.
I added a simple "discount" controller as well as the touchscreen.
Control arduino mega RAMPS board is a MKS GEN L V1.1
Edited 1 time(s). Last edit at 05/17/2018 03:44PM by Tryit.
Re: I can't get part cooler fan to work.MKS GEN L V1.1 / Marlin
May 18, 2018 02:07AM
Question is, how did you configure your board? In Marlin you configure Ramps as EFB* or EEB or EFF, depending how you want to use the three MosFets.
Is there an option like this for the MKS board?
*E = extruder, F = fan, B = bed
May 18, 2018 05:24AM
Trying to see if I can figure this out - I am looking to find out how to send debug messages from marlin.
