New RAMPS design June 05, 2018 04:11PM |
Re: New RAMPS design June 06, 2018 03:26AM |
Re: New RAMPS design June 06, 2018 04:38AM |
Admin Registered: 13 years ago Posts: 7,000 |
Re: New RAMPS design June 06, 2018 09:47AM |
o_lampe
- Better fuses and
- stronger 5V regulator.
- Keep it open source. There are a few "new" Ramps boards but they are not OS.
- I'd keep my hands off of Arduino Due, since it is buggy to start with ( and RADDS already exists )
Re: New RAMPS design June 06, 2018 09:52AM |
Re: New RAMPS design June 06, 2018 11:35AM |
Re: New RAMPS design June 06, 2018 12:09PM |
Re: New RAMPS design June 07, 2018 06:20AM |
Re: New RAMPS design June 07, 2018 06:44AM |
Re: New RAMPS design June 07, 2018 08:31AM |
Re: New RAMPS design June 07, 2018 01:38PM |
o_lampe
I couldn't identify microstepping jumpers, are there any or do you use FW configurable drivers?
Re: New RAMPS design June 07, 2018 01:54PM |
o_lampe
I see you have two parallel headers for stepper motors on XYZ steppers, but with 24V ( or more ) it would be nicer to wire them in serial fashion.
Dust
I agree about serial vs parallel steppers but as a 3rd stepper connector. This is wired in series. Making it easy to have dual stepper in series or parallel as needed.
Re: New RAMPS design June 07, 2018 02:02PM |
o_lampe
The whole onboard fuse could be skipped, when using inline blade fuses from car-suppliers.
Re: New RAMPS design June 07, 2018 03:53PM |
xebbmw
I also built a new shield based on Arduino Due. Actually two shields, both based on Arduino Due. One shield has 5 steppers and the second 6 steppers. The second board allows the use of TMC2130 steppers that are configurable via the SPI bus. The second board I am about to start testing.
xebbmw
I am a fan of Repetier firmware that I used from the beginning when I build my Delta printer.
Good to know about this project. I wonder why it does not appear to have a mention on the Reprap.og wiki. As I did try to find other shield-style boards, ment to be use with the Due, before I started on this project.
This is possible with this board, as the steppers have their own power connector. As does the heat bed. And then a power connector for the rest of the board. So it has three power connectors in all, making it possible to chose voltage for each section individually.Quote
xebbmw
I few ideas you might consider: the whole board can run at 12V, except the stepper motors.
xebbmw
I few ideas you might consider: the whole board can run at 12V, except the stepper motors. To power the board by 24V you need dc-dc boost converter to bring everything to 12V. In the same way, you need another dc-dc boost converter to get 5V for the board. Maybe 5V is not needed, but I wanted to be able to use the graphic LCD controller.
Hmmm... what kind of temperature reading are you thnking about? There are already three ports to read temperature.Quote
xebbmw
You might consider using thermocouple or PT100 for temperature readings.
Re: New RAMPS design June 07, 2018 04:00PM |
Dust
I think its time to drop as much through hole as possible
Re: New RAMPS design June 07, 2018 07:26PM |
MrAlvin
Good to hear about it. Do you happen to have any online information or some photos you would like to share?
Re: New RAMPS design June 08, 2018 03:12PM |
Re: New RAMPS design June 08, 2018 03:40PM |
Thank you, I will take a look at them. So far I have noticed the very interesting placing of the drivers, underneath the shield PCB. I will be interested in hearing about your experience, of how that affects the cooling/heating of the drivers.
xebbmw
About mosfets, I use IRLR8743 in one board for the bed. It holds well, it is in SMD package and it is mounted on the board (some of the circuit used as heat sink). I tried to use IRLR2905 for the hot ends, but it did not work well as they were quite hot. Or maybe the ones I have are fakes, I bought them from China. Then I replaced them with IRLR8743 and it is just fine. For Due6Step I want to use also IRLB3034, as you see in the picture they are not soldered yet.
Thank you for the link to that discussion.Quote
xebbmw
Regarding the SPI signals for TMC2130, I use the same jumpers as you do. Each jumper has two positions when TMC2130 or regular stepper drivers are installed. I mentioned more details here.
Re: New RAMPS design June 08, 2018 06:21PM |
The idea of placing the stepper drivers underneath the PCB is that I have a Delta printer. I am going to place the controller board at the bottom of the printer, below the heat bed where is not that much space. Thus I thought that placing the drivers underneath will reduce the vertical space occupied by the controller board. I will place everything in a printed box with some fans, I guess it should be fine.Quote
MrAlvin
So far I have noticed the very interesting placing of the drivers, underneath the shield PCB. I will be interested in hearing about your experience...
Thanks a lot for educating me. For me electronics is just a hobby, I am doing software programming as job in real life.Quote
MrAlvin
So the resulting heat calculation looks something like this: I x I x R x C = degree Celsius above ambient room temperature.
The fuse holders that I have are 3544-2 from Keystone. I bought them from Digikey but I see they are available also on AliexpressQuote
MrAlvin
By the way, I would be interested to hear where you get those sockets for the blade fuses. I have so far not been able to find a good (and low cost) source.
Re: New RAMPS design June 09, 2018 03:36AM |
maso
Regarding fuses:
I recently blew the fuse on a Duet 0.6 board, and was surprised to find that @dc42 has since then moved to a self-resetting fuse in his designs.
I made the modification to add it to my board, and find that to be a really nice feature, considering my likelihood of forgetting to turn off the board prior to working on the hotend.
I can't find the post about it at the moment, but in my notes I wrote down his suggested part numbers:
Multicomp MC36207 from Farnell
Bourns MF-MSMF014
Bel Fuse 0ZCJ0020FF2E
He also added a means of detecting the VSSA short with a 10k inline resistor to an I/O pin.
Re: New RAMPS design June 09, 2018 05:58AM |
dc42
Just to be clear, this is a fuse to protect the analog ground connection from shorts, not a fuse in the power circuitry.
That is indeed the design challenge.Quote
dc42
It's hard to fuse the bed heater circuit in a meaningful way, because ordinary fuses won't blow unless they receive a substantial overload for several seconds. Meanwhile it's likely that a PCB trace will fuse, or the PSU will detect the overload and go into hiccup mode.
Re: New RAMPS design June 09, 2018 12:47PM |
Ah yes, that makes good sense.Quote
xebbmw
You are quite welcome. I used to work with computers and networks, so electronics is also a hobby for me.Quote
xebbmw
Thank you for the parts info, and the link. It has given me good clues of what to look for next.Quote
xebbmw
Re: New RAMPS design June 12, 2018 07:44PM |
Re: New RAMPS design June 13, 2018 03:04AM |
You have a good point for a more universal stepper-driver-holder-board.Quote
aenertia
* ESP32 / $Whatever MCU boards should be well supported - I am over the arduino pinout configuration in general and think that the RAMPS series needs to seriously consider removing the Header pinout found on the older AVR duinos as a primary consideration for pinout. Just provide a row of headers for MCU attachment generally something like the 40PIN header found on the RPI's etc. the STM7 dev boards and the LPC chips which are the re-arm targets are not generally found in the Arduino baseboard layout so something generalized is IMNSHO a better bet. The upshot of this is better placement options for other components.
As I try to keep the board as small as possible, this design also only has a AUX port option (Aux-1). For 5V operation of the board, and connecting to 3V devices for Bluetooth or WiFi, it does however have a duplicate of the AUX pins, where a voltage divider has been added to the TXO pin, so this pin only sends out 3V to the Bluetooth or WiFi device.Quote
aenertia
* As a corollary to the above - a lot of the boards now include Wifi AUX connectors ; whilst I appreciate there is nothing preventing someone from using any of the AUX ports for this purpose; some consideration to aerial and RF interference in terms of placement for this reason is probably worth considering.
Thank you.Quote
aenertia
* Most of the Unofficial RAMPs boards use surface mount mosfets with through PCB heat sink - the kicad you posted looks like this - so kudos!
Fuses that can blow (and then be replaced) are indeed part of their intended functionality :-)Quote
aenertia
* Am for keeping replaceable fuses, either barrel or Car style is good a bet; being able to actually replace fuses is a bonus - considering the point of them is to blow.
I am not quite sure what you are saying here?Quote
aenertia
* I think a reference set of components would be a good idea - obviously the tmc2100 drivers are the dujour, but likewise with overrated mosfets; seems the target draw in many reviews seems to be in the 11-12A range; some maybe providing some higher end base tolerances for components would be a good idea.
Re: New RAMPS design June 13, 2018 08:45AM |
What micro controller is used on your MOOZ board?Quote
aenertia
Couple of comments; as I am looking to replace the stm7f proprietary board in my MOOZ which is proprietary and doubtful due to various SPI backed hacks I can reverse engineer into something usable with Mainline Marlin 2.0 at this point.
Re: New RAMPS design June 14, 2018 05:39PM |
Re: New RAMPS design June 14, 2018 06:47PM |
Re: New RAMPS design June 17, 2018 05:47PM |
Re: New RAMPS design June 17, 2018 06:17PM |
Re: New RAMPS design June 17, 2018 07:13PM |
aenertia
Is Due event a consideration (it's not even produced anymore)
aenertia
SPI controlled Motor controllers are likely going to be the norm
aenertia
(to support multi-colour extruders) (zyz, rgbbw)
aenertia
Ability to interface $userschoice of MCU - assume no specific pinout
