Re: New RAMPS design July 03, 2018 12:00PM |
Re: New RAMPS design July 03, 2018 12:10PM |
Re: New RAMPS design July 03, 2018 03:43PM |
Re: New RAMPS design July 03, 2018 04:19PM |
Re: New RAMPS design July 04, 2018 02:35AM |
dc42
You can use a portion of the flash memory in the Due as a substitute for EEPROM. It has lower write endurance than true EEPROM, but this is unlikely to be a problem. If necessary you can use wear levelling to mitigate it. Alternatively, use a file on the SD card to save the parameters, as the leading 32-bit firmwares do.
Re: New RAMPS design July 04, 2018 02:47AM |
Re: New RAMPS design July 06, 2018 05:23PM |
Re: New RAMPS design July 07, 2018 09:57AM |
dc42
Re: New RAMPS design July 07, 2018 02:50PM |
Re: New RAMPS design July 07, 2018 03:00PM |
Re: New RAMPS design July 07, 2018 03:31PM |
boelle
I like the screw terminals near the blue fuse
any chance the remaining 8 can be same type?
Re: New RAMPS design July 07, 2018 03:36PM |
Re: New RAMPS design July 08, 2018 02:40AM |
Re: New RAMPS design July 08, 2018 05:00AM |
Re: New RAMPS design July 08, 2018 12:53PM |
o_lampe
I see a potential problem there:
[attachment 105974 bf_800x400.png]
If someone uses a too long wire for the terminal, it could make contact with the bare back of the MOSFET.
Re: New RAMPS design July 08, 2018 01:19PM |
boelle
yeah, i would have crimped on a ferrule
Re: New RAMPS design July 08, 2018 01:22PM |
Re: New RAMPS design July 08, 2018 01:27PM |
Re: New RAMPS design July 08, 2018 01:31PM |
boelle
about the fork style terminals
i had the same problem with one of the 30A LED psu's
what i did was folding the 2 forks to it became a pin instead, cant quite remember how i did it it but it was easy enough
i basicly ended up with both forks on top of each other
Re: New RAMPS design July 08, 2018 01:36PM |
Re: New RAMPS design July 08, 2018 06:25PM |
Re: New RAMPS design July 09, 2018 04:12AM |
Re: New new RAMPS design July 18, 2018 04:27PM |
Re: New new RAMPS design August 03, 2018 10:59AM |
Re: New new RAMPS design August 03, 2018 11:13AM |
Re: New new RAMPS design August 03, 2018 11:15AM |
Re: New RAMPS design August 20, 2018 11:42PM |
Re: New RAMPS design August 27, 2018 11:26AM |
Re: New RAMPS design August 28, 2018 08:01AM |
rootboy
Hi guys,
If it's not too late to make a suggestion, I recommend these connectors:
[www.digikey.com]
They are screwless terminals, similar to what we use which are mounted to DIN rail in industrial control panels. The beauty of these connectors is that they simply do not come loose, and there isn't any screw to strip out.
