Re: New RAMPS design January 29, 2019 04:35PM |
Re: New RAMPS design February 04, 2019 01:49PM |
Re: New RAMPS design February 06, 2019 10:07AM |
kabelfrikkler
If you Like i now have a new Oscilloscope should have moste of the componments here, and can have a look on the PCB
kabelfrikkler
i could do some testing wih arduino mega tmc2130 and my new oscilloscope:-)
I use double sided PCB. As one of the original design goals were to keep it simple and low cost.Quote
kabelfrikkler
Do you have two ore more sided PCBs?
There is no repository - yet.Quote
kabelfrikkler
is there a repository I havend found one
Re: New RAMPS design February 27, 2019 04:16PM |
Re: New RAMPS design March 03, 2019 09:45PM |
RX14
I looked through the thread and I can't find exactly what changes 1.7C entails.
RX14
But given I made this mess attaching just two TMC2130's to my board, I'm very interested in RAMPS 1.7! Definitely interested in testing my own board once the design stabilises.
Re: New RAMPS design March 05, 2019 06:10PM |
MrAlvin
RX14
Actually I do not think that is messy at all. Jumper wires are jumper wires, and they will always add a new layer of visual impression.
But I hear you: sometimes one just dreams of no-jumper-wire solutions :-)
Re: New RAMPS design March 06, 2019 07:30AM |
Re: New RAMPS design May 07, 2019 08:16PM |
Re: New RAMPS design August 20, 2019 05:20PM |
Re: New RAMPS design August 21, 2019 07:45AM |
Re: New RAMPS design August 21, 2019 01:41PM |
RX14
BTW, a bit of a bug on original RAMPS 1.4 is that the PSU pin tends to pull down when the arduino is unpowered, causing the power supply to turn on and get into a loop of the printer switching on and off when USB power is disconnected. This is solved by powering the arduino exclusively over USB, but that's not ideal.
Has high-Z at rest on PS_ON been considered in RAMPS 1.7?
Re: New RAMPS design August 21, 2019 01:52PM |
Re: New RAMPS design August 21, 2019 02:11PM |
MMcLure
Marlin already supports inverting the power supply pin. Just set POWER_SUPPLY to 2 (on Marlin 1.1.x) or set PSU_ACTIVE_HIGH (on current bugfix-2.0.x) to use active high to enable the power supply.
Re: New RAMPS design August 21, 2019 02:43PM |
Re: New RAMPS design September 05, 2019 12:28AM |
Re: New RAMPS design September 05, 2019 03:54AM |
Re: New RAMPS design November 16, 2019 02:16AM |
Re: New RAMPS design November 16, 2019 07:55PM |
MrBW
Hi folks,
I'm new here in the forum. This is a really interesting thread. Are there any news about the result of the tests of the two boards?
Re: New RAMPS design November 17, 2019 11:28AM |
Re: New RAMPS design December 16, 2019 12:39PM |
Re: New RAMPS design December 16, 2019 06:05PM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: New RAMPS design December 16, 2019 07:10PM |
Admin Registered: 13 years ago Posts: 7,001 |
Re: New RAMPS design December 16, 2019 07:18PM |
Re: New RAMPS design December 16, 2019 07:50PM |
makermelissa
Hello,
Is there any new word on this? I'm very interested in trying this out with the Adafruit Grand Central.
Thanks,
Melissa
That is correct. This RAMPS shield is designed so it can work well with both the 8-bit Mega as well as 32-bit controllers that provieds the Arduino Mega style connector pins. As does the DUE, Re-ARM and the AGCM4 controllers.Quote
makermelissa
It seems like the purpose of this RAMPS is to allow the use on 32-bit boards utilizing the Arduino Mega form factor.
Ohmarinus
With the developments of the new cheap 32-bit boards, Ramps is becoming obsolete quickly. I suggest not investing in a Ramps board anymore as the new SKR 1.4 has very promising specs for a similar price (and you don't need to stack it onto an Arduino mega). I predict that Ramps boards will be discontinued in the next year.
Re: New RAMPS design December 17, 2019 06:20AM |
MrAlvin
Indeed, with the prices going down on the new 32-bit all-in-one boards, the old 'Mega/RAMPS 1.4 combo', is slowly, but surely, being pushed aside.
For those who value the flexibility of the old RAMPS 1.4 shield (as Dust already mentioned), this new RAMPS 1.4.4 shield will continue to offer this level of flexibility for use with 32-bit controllers.
For instance, just the other day, someone asked if it would be possible to control 8 hotend tools from this RAMPS 1.4.4 shield. And 8 hotend tools would be: 8 steppers, 8 hotends, 8 fans and 8 thermistors. After designing a few plug-in boards that connect to Aux1-4, it does indeed seem to be very possible.
I wonder if those all-in-one boards has enough expansion pins, to be able to be extended like that.
Either way, this project is still (slowly) moving forward.
Re: New RAMPS design March 10, 2020 02:18AM |
Re: New RAMPS design March 10, 2020 06:03AM |
GRAYWOLF
Hi, I have been absent for ages (only back as rebuilding my i3) where can I purchase 1.4.4?
Re: New RAMPS design March 10, 2020 02:32PM |
MrAlvin
GRAYWOLF
Hi GRAYWOLF,
so far you can get files and/or pcb and/or an assembled and tested shield from me. I will send you a PM via the message system, so you can get more information. Okay?
Alvin
Re: New RAMPS design March 29, 2020 01:27PM |
Re: New RAMPS design March 29, 2020 02:33PM |
xsiriox
Hi MrAlvin, I'm also very interested to your ramps 1.4.4 board! Can you tell me informations about how to buy one, and if is it possible how to use it with drivers like tmc2208 in uart setup?
Thankyou very much!
xsiriox
