Negative spikes, not sure what is going on ![]() June 26, 2018 06:41PM |
Re: Negative spikes, not sure what is going on ![]() June 26, 2018 09:08PM |
Re: Negative spikes, not sure what is going on ![]() June 27, 2018 03:19AM |
Re: Negative spikes, not sure what is going on ![]() June 27, 2018 03:27AM |
o_lampe
IDK if Marlin is polling the AD converters or uses interrupts? If it's polling, then maybe the AD-conversion is still ongoing while Marlin polls the value?
Interrupt handling routines are also tricky, especially with a constant data stream from Arduino to OctoPi.
Re: Negative spikes, not sure what is going on ![]() June 27, 2018 03:34AM |
Re: Negative spikes, not sure what is going on ![]() June 27, 2018 03:58AM |
Re: Negative spikes, not sure what is going on ![]() June 27, 2018 04:08AM |
Re: Negative spikes, not sure what is going on ![]() June 27, 2018 05:18AM |
Re: Negative spikes, not sure what is going on ![]() June 27, 2018 07:35AM |
Re: Negative spikes, not sure what is going on ![]() June 27, 2018 07:46AM |
o_lampe
I'm sure the LCD values are filtered or averaged. Otherwise we would only see dancing pixels. Might be, that the data sent to octoprint are raw sensor values without bandwidth filtering or averaging.
The capacitors on Ramps might be too small or mislabelled crap. We've seen that in the past too often..
Re: Negative spikes, not sure what is going on ![]() June 27, 2018 09:09AM |
Re: Negative spikes, not sure what is going on ![]() June 27, 2018 09:18AM |
Re: Negative spikes, not sure what is going on ![]() July 21, 2018 03:02PM |
Re: Negative spikes, not sure what is going on ![]() July 22, 2018 02:37AM |
Re: Negative spikes, not sure what is going on ![]() July 22, 2018 04:26AM |
Re: Negative spikes, not sure what is going on ![]() July 22, 2018 05:45AM |
Re: Negative spikes, not sure what is going on ![]() July 22, 2018 07:08AM |
Re: Negative spikes, not sure what is going on ![]() July 22, 2018 07:45AM |
Re: Negative spikes, not sure what is going on ![]() July 22, 2018 10:55AM |
Re: Negative spikes, not sure what is going on ![]() July 23, 2018 06:48PM |
Re: Negative spikes, not sure what is going on ![]() July 24, 2018 05:03AM |
Re: Negative spikes, not sure what is going on ![]() July 24, 2018 05:51AM |
Re: Negative spikes, not sure what is going on ![]() July 24, 2018 06:19AM |
Re: Negative spikes, not sure what is going on ![]() July 31, 2018 05:14PM |
Re: Negative spikes, not sure what is going on ![]() July 31, 2018 05:17PM |
Re: Negative spikes, not sure what is going on ![]() July 31, 2018 05:20PM |
