hunt Down comunication errors on Ramps 1.4"ish"
August 10, 2018 09:35AM
hey everyone,
I got some wired Issues like.. for 5month now and i dont find it.
setup: Arduino Mega / modified Ramps Marlin 1.8 // 2.0-dev
I can print.. 5-20miuts than i get com-errors and the serial comunication brakes.
I tried Octoprint(not Octopi) and Pronterface same problem so no host problem
I tried Marlin 1.8 1.8 with advanced OK and Marlin 2.0-dev so maybe no firmware Problem
I tried a diffrent Arduino board.
I tried 3diferrent USB cables, and finaly even wrapped Aluminium foil around them. no change
i do run only 112500 baudrate...
I dont have a clue on how to proceed.
** any hints ar wellcome but dont tell me to switch the powersuply of my pi ;-)
Re: hunt Down comunication errors on Ramps 1.4"ish"
August 10, 2018 09:42AM
5amp polyfuse getting hot and randomly powering down the mega?
Bad ramps powersupply? (under rated for current or old with bad caps?)
using a glcd? (they suck to much current) try unplugging it
Edited 1 time(s). Last edit at 08/10/2018 09:43AM by Dust.
August 10, 2018 09:51AM
no polyfuses,
the powersuply is 20A and the Heated Bed is 230V but maybe the Relay is sucking to much on 5V and no display or SD
how would i find out the Powersuply has Bad caps? I have no oszi. but i could add a few supression caps ..
and Thanks for the serios answer^^
Edited 1 time(s). Last edit at 08/10/2018 09:51AM by kabelfrikkler.
August 10, 2018 10:11AM
The 5v rail is not very powerful
Is this a mechanical relay? how is it connected? to 12v mosfet output or 5v digital?
If it is 5v can you use something like an optical isolater and a separate coil power supply?
August 10, 2018 10:40AM
jep it is on vcc and as i run 30V it is only powerd via USB but the 5v Rail is (with the rely on) on 4.87V but i keep that in mind too the 5v rail is pretty weak your right
To be sure on the PSU (it is a Meanwell china (clone) ) I just got my two car batteries up and started a Print
@Dust ((do you know a good linear Voltage regulator by the way 2-3A? regulatin from ~+6to +11V))
