MKS Gen L and RepRap display + Z axis travel
December 20, 2018 03:08PM
Genuine MKS Gen L
BigTree Tech - Discount RepRap Smart Controler.
Marlin 1.1.9 BugFix release.
I was getting nothing on the display not even the back light so I've followed one of the "fixes" and reversed the Number 1 ribbon cable connector.
Now I have the blue back light and white rectangles where the text should be but sadly no text.
What's next? I've seen references to enabling a different display which one should I choose?
Will I damage anything if I work in order through the options Marlin offers?
Moving on, I have X, Y and Z moving but Z does not stop when the end stop is triggered manually although the LED on the end stop pcb does illuminate.
The Z end stop is plugged into Z min and defined as Z min in Marlin although it is inverted.
Any Advice much appreciated.
Thanks All. Aamcle
Re: MKS Gen L and RepRap display + Z axis travel
December 20, 2018 05:19PM
in configuration.h
// RepRapDiscount Smart Controller.
// [reprap.org]
// Note: Usually sold with a white PCB.
//#define REPRAP_DISCOUNT_SMART_CONTROLLER
remove the // from the #define
recompile and upload into the machine.
Make sure the motherboard is set to Gen_L ie
#define MOTHERBOARD BOARD_MKS_GEN_L
Edited 1 time(s). Last edit at 12/20/2018 05:25PM by Dust.
December 20, 2018 05:29PM
That is the current setting the reprap discount smart controller is the one defined.
I've read that there is a incompatibility between genuine MKS Gen L boards and some clone controllers and I unfortunately have a clone.
Any idea whats up with the Z axis?
Thanks Alan.
December 21, 2018 12:23PM
I've no experience with MKS Gen L, but when I had to revers ribbon cable orientation for Smart LCDs, I always had to revers both.
Calling any MKS board 'genuine' is a punch in anyones face, they stole from.
