Hello. I had made prusa i3 and facing some problem. As I turn on my 3d printer the heatbed automatically start heating up without setting up the Max temperature. For reference i had upload the picture of my lcd(heatbed.png) after few minutes the 3d printer was on . I have 12V, MK3 Aluminum Heatbed and connected through heatbed power module. I had also upload Marlin Firmware. I hope if anyone can help me out. Thank you
Link for Mosfet used. [www.amazon.com]
Edited 1 time(s). Last edit at 01/09/2019 01:55PM by Abdul Mannan.
open | download - heatbed.png (815.8 KB)
open | download - Marlin.txt (143.6 KB)
Check and make sure that the tabs on the MOSFETs on the RAMPS board aren't touching. That can cause weird behavior with the heaters.
Thanks for reply and I have check the tabs they are fine. The problem is the same.
Did you observe the polarity of the signal cable going from RAMPS D8 to the MOSFET board? (It seems the cable wires are coded with dashes and dots...)
Thanks for the reply, I have checked the polarity of the signal cable by swapping them but nothing changed. I had find the actual problem. The ramps D8 is continually giving 12v output when the bed temp is set to 0 degree which results into automatically heating up. Where as the D9 and D10 are giving 0V when they are set at 0. Is there is any setting for it in Marlin Firmware.
Abdul Mannan
D8, D9 and D10 are switched at the ground (-) side, while the (+) is directly connected to 12V - so you will always measure 12V at the (+) side of the connector.
Does the D8 LED light up when you switch on the heatbed and remain dark when it's not active?
Can you show us a photo of your wiring between the RAMPS, the MOSFET board and the power supply?
Thanks for the reply. I have attached 6 pictures which are taken when the 3d printer is power up and no setting changes are made (when bed temp, fan and hotend temp are at 0 degree). As you can see in(as power up.JPG) the ramp D8(red) and mosfet light(blue) is turned on when the Heatbed temperature not activate or is set to 0 degree. As in(D8.JPG) you can see it is giving 12V when the bed temp is set to 0 degree in(lcd.png). Where as in(D9.JPG, D10 JPG) you can see it is giving 0V when the temp and fan is set to 0 degree in(lcd.png). The black wire with white tape represent positive wire which I put in place of red wire.
Edited 1 time(s). Last edit at 01/11/2019 10:06PM by Abdul Mannan.
open | download - D8.JPG (834.6 KB)
open | download - D9.jpg (783.2 KB)
open | download - D10.jpg (648.4 KB)
open | download - as power up.JPG (681 KB)
open | download - power supply.png (857.1 KB)
open | download - lcd.png (815.8 KB)
Re: Heatbed Automatically Heating up without setting temperature and reach more than 100 degree.
January 11, 2019 11:58PM
The D8 mosfet is clearly on
I would check the numbers on the D8 mosfet, perhaps they have swapped it for something else?? something that is on when the gate is low (unlikely)
Then you need to measure the input the the D8 mosfet
-ve probe to gnd
+ve probe to mega D8 pin on ramps (just above the E0 plug)
meter set to volts, a range that will show 5v.
if its 0, you have a dead d8 ramps mosfet that is always on
if its is 5v, something in firmware is turning it on.
As a final test install ramps test firmware, without any changes. It will move all steppers and turn all mosfets on and off
[reprap.org]
Edited 1 time(s). Last edit at 01/12/2019 12:03AM by Dust.
Thanks for the reply. I had check the voltage twice, Once by powering up 3d printer and not changing the temperature/ or temp was 0 degree with the pictures named(D8 closed.JPG, D9 closed JPG). I had measured D9 Mosfet as well to compare with it. Then I set the heated bed temp to max(95') and fan to max(255) and then measure the voltage(D8 open.JPG, D9 open.JPG). As according to it D8 Mosfet is dead so I was thinking that rather than changing whole Ramp board or changing only D8 Mosfet. I can just flip the D8 pin setting in Marlin Firmware to D9 pin which will change EFB to EBF. As I am using 3 fans, 1: for ramp board(fan/5V), 2: Hot end(fan/5V), 3: cooling 3d print(blower/12v) I can power up the blower at its max speed and that will not be an issue. But will there be any problem if I change it and how exactly I would be able to change the setting in Marlin firmware.
open | download - D8 closed.JPG (905.4 KB)
open | download - D9 closed.JPG (888 KB)
open | download - D8 open.JPG (709.1 KB)
open | download - D9 open.JPG (814.9 KB)
January 13, 2019 01:23AM
The -vs on the mosfet plugs D8, D9 and D10 are switched to gnd. They are not always ground and shouldn't be use to measure other things. (only use it when checking volage out of the mosfet)
Use a gnd on the power plug or a gnd pin elsewhere...
Re moving D8 to D9 If you use the external mosfet board this is fine
open up pins_RAMPS.h and find
#ifndef RAMPS_D8_PIN
#define RAMPS_D8_PIN 8
#endif
#ifndef RAMPS_D9_PIN
#define RAMPS_D9_PIN 9
#endif
swap the 8 and the 9 around
Thanks for the reply. My problem has been resolved but now in D8 I have install blower/12V to cool 3d print and is continuously running. Will that be any issue or not?
