FlashAir
January 17, 2019 01:54PM
Hello, I recently discovered this wonderful little SD card.
Discovered them from Chris Riley through this vid: WiFi SD Card
I can save my gcode files straight to the SD card through Wifi, BUT the Marlin firmware (1.1.9) wont read the card.
(The card powers up, I can find and save files to the card so, "its working")
Marlin detects that its inserted, but when I go to load the code from from the menu, it says "No SD card"
I made the changes listed here: Marlin Firmware Patch
But that didn't help.
Any suggestions?
Custom all metal CoreXY
- Duet 2 Wifi w/ PanelDue 7i
- 330mm x 360mm x 500mm
- 750w Silicon heater
Custom Mendel90
(Backup printer - Old reliable!) - Sold
Re: FlashAir
February 06, 2019 04:50PM
Nobody playing with these wifi cards?!
Custom Mendel90
Re: FlashAir
February 06, 2019 09:13PM
I was looking at the code in Marlin 1.1.9 Bugfix looks like it has already been modded for WiFi Cards.
  // discard CRC
  spiRec();
  spiRec();
#endif
  chipSelectHigh();
  // Send an additional dummy byte, required by Toshiba Flash Air SD Card
  spiSend(0XFF);
  return true;
  FAIL:
  chipSelectHigh();
  spiSend(0XFF);
  return false;
Edited 1 time(s). Last edit at 02/06/2019 09:13PM by Roberts_Clif.
Re: FlashAir
February 06, 2019 11:41PM
people where trying ti use these 2 years back... the general consensus was uploads are just to slow.
VDX
Re: FlashAir
February 07, 2019 02:43AM
... yes, I've tested them for a project with file sizes of up to 2 GB, what was not really usefull - so changed to hardwired instead eye rolling smiley
Viktor
Re: FlashAir
February 07, 2019 09:57AM
Uhmm... I actually found transfer speeds really quick.
Just need the ramps to read the file after the transfer.
Custom Mendel90
