We have a section dedicated to RAMPS (I have requested that this be moved to the RAMPS section)
1A, 1B, 2A, 2B on the pololu are the output pins these go to the stepper motors
The inputs are listed in pins_RAMPS.h as follows (these are in arduino naming convention)
With standard pololu stepper drivers you can ignore the CS pins, that is for 'smart' stepper drivers with SPI ports.
// Steppers
#define X_STEP_PIN 54
#define X_DIR_PIN 55
#define X_ENABLE_PIN 38
#ifndef X_CS_PIN
#define X_CS_PIN 53
#endif
#define Y_STEP_PIN 60
#define Y_DIR_PIN 61
#define Y_ENABLE_PIN 56
#ifndef Y_CS_PIN
#define Y_CS_PIN 49
#endif
#define Z_STEP_PIN 46
#define Z_DIR_PIN 48
#define Z_ENABLE_PIN 62
#ifndef Z_CS_PIN
#define Z_CS_PIN 40
#endif
#define E0_STEP_PIN 26
#define E0_DIR_PIN 28
#define E0_ENABLE_PIN 24
#ifndef E0_CS_PIN
#define E0_CS_PIN 42
#endif
#define E1_STEP_PIN 36
#define E1_DIR_PIN 34
#define E1_ENABLE_PIN 30
#ifndef E1_CS_PIN
#define E1_CS_PIN 44
#endif
you also might want to look at the ramps test firmware.. it moves all stepper back and forward and turn on the mosfets.
RAMPS1.4 Test code
So on the RAMPS you have 5 stepper drivers, labeled X, Y, Z, E0 and E1 You need to work out which ones you are using.
Each polulu stepper driver takes 3 digital input signals
Enable (active low) enables the driver chip and energizes the stepper motor.
Direction, sets the direction of movement, clockwise or anticlockwise
Step, move one step in the direction set above. NB with microstepping you may not get physical movement each Step, but it will jump to correct place when it can
Edited 8 time(s). Last edit at 04/30/2019 08:08AM by Dust.
