Ramps 1.4 LCD showing 2 white "block" lines May 03, 2019 08:22AM |
// RepRapDiscount Smart Controller. // [reprap.org] // // Note: Usually sold with a white PCB. // #define REPRAP_DISCOUNT_SMART_CONTROLLERbut it always shows 2 white lines no matter what. I tried the screen in my first delta and it works (and the other way around that the LCD from the first one does not work on this one). I tried switching the cables, rotating them, reflashing it multiple times and still the same problem.
Re: Ramps 1.4 LCD showing 2 white "block" lines May 03, 2019 06:43PM |
Re: Ramps 1.4 LCD showing 2 white "block" lines May 04, 2019 12:50AM |
Re: Ramps 1.4 LCD showing 2 white "block" lines May 04, 2019 01:03AM |
Re: Ramps 1.4 LCD showing 2 white "block" lines May 04, 2019 03:50AM |
It works with other boards, so the LCD is fine and working (if anything, there might be a bit of hot glue, but the LCD is fully working on my other delta).Quote
Dust
Under the d in "rrd" along the top of your LCD adapter is a blob of solder that should not be. But that is on the kill button.
The pins that are required for LCD are
#define LCD_PINS_RS 16
#define LCD_PINS_ENABLE 17
#define LCD_PINS_D4 23
#define LCD_PINS_D5 25
#define LCD_PINS_D6 27
#define LCD_PINS_D7 29
Looking closely at the top of the LCD adapter at these 6 pins a few look dodgy.. In particular 23,25 and 27.
I would hit them all with some fresh flux and solder.
Re: Ramps 1.4 LCD showing 2 white "block" lines May 04, 2019 07:41AM |
//Standard RRD smart controller LCD pins when on a RAMPS 1.4 //lcd pins #define LCD_PINS_RS 16 //[RAMPS14-SMART-ADAPTER] #define LCD_PINS_ENABLE 17 //[RAMPS14-SMART-ADAPTER] #define LCD_PINS_D4 23 //[RAMPS14-SMART-ADAPTER] #define LCD_PINS_D5 25 //[RAMPS14-SMART-ADAPTER] #define LCD_PINS_D6 27 //[RAMPS14-SMART-ADAPTER] #define LCD_PINS_D7 29 //[RAMPS14-SMART-ADAPTER] #define screenX 20 #define screenY 4 #include <LiquidCrystal.h> #define LCD_CLASS LiquidCrystal LCD_CLASS lcd(LCD_PINS_RS, LCD_PINS_ENABLE, LCD_PINS_D4, LCD_PINS_D5, LCD_PINS_D6, LCD_PINS_D7); //RS,Enable,D4,D5,D6,D7 void setup() { lcd.begin(screenX, screenX); // Print a message to the LCD. lcd.print("hello, world!"); lcd.setCursor(0, 1); lcd.print("I am not a reprap."); lcd.setCursor(0, 2); lcd.print("But we are working"); lcd.setCursor(2, 3); lcd.print("on that..."); } //Main arduino loop void loop() { }
Re: Ramps 1.4 LCD showing 2 white "block" lines May 04, 2019 08:51AM |
Yea, it does not work, but thanks for trying. Instead of anything, now I get one and a half of white block lines (so pretty much the same).Quote
Dust
ok... compile and upload this 20x4 LCD test sketch. DO NOT MODIFY IT, it works as is on a RAMPS
If this works, its a firmware issue.
If this doesn't work, its a hardware issue. (ramps or arduino)
Re: Ramps 1.4 LCD showing 2 white "block" lines May 04, 2019 09:29AM |
