Replace Ramps LCD by button May 20, 2019 04:46AM |
Re: Replace Ramps LCD by button May 20, 2019 07:38AM |
Admin Registered: 13 years ago Posts: 7,000 |
/* Button Turns on and off a light emitting diode(LED) connected to digital pin 13, when pressing a pushbutton attached to pin 16. The circuit: - LED attached from pin 13 to ground - pushbutton attached to pin 16 from +5V - 10K resistor attached to pin 16 from ground - Note: on most Arduinos there is already an LED on the board attached to pin 13. created 2005 by DojoDave [www.0j0.org] modified 30 Aug 2011 by Tom Igoe This example code is in the public domain. [www.arduino.cc] */ // constants won't change. They're used here to set pin numbers: const int buttonPin = 16; // the number of the pushbutton pin const int ledPin = 13; // the number of the LED pin // variables will change: int buttonState = 0; // variable for reading the pushbutton status void setup() { // initialize the LED pin as an output: pinMode(ledPin, OUTPUT); // initialize the pushbutton pin as an input: pinMode(buttonPin, INPUT); } void loop() { // read the state of the pushbutton value: buttonState = digitalRead(buttonPin); // check if the pushbutton is pressed. If it is, the buttonState is HIGH: if (buttonState == HIGH) { // turn LED on: digitalWrite(ledPin, HIGH); } else { // turn LED off: digitalWrite(ledPin, LOW); } }
Re: Replace Ramps LCD by button May 20, 2019 11:54AM |
