Laser LA03-5000 wiring
Posted by Fires
May 29, 2019 06:53AM
Hi guys, I'm totally lost. I was searching about 2 days how to correctly wire Blue Laser LA03-5000 to ramps 1.4 board.
This laser has 12V input and separate pwm/ttl wires. I find how to control laser with no PWM ( just hook it to D9 same as fan.) but how wire correctly this type of laser ? Thanks for your advice .. I really want wire it corrent for safety reasons.
Re: Laser LA03-5000 wiring
May 29, 2019 09:01AM
I would still connect it to D9 for 12v and use that as a master on/off switch
the PWM you connect to a PWM pin (5v ) use the pins on the servo connector say D4 and the Gnd or D5 or D6 or D11.
Change your firmware so the fan pin is this PWM pin then software that uses fan on/off still works.
you will need M42 P9 S255 for power on
and M42 P9 S0 for power off
Put in start and end gcodes or equivalent
May 29, 2019 09:16AM
Thanks .. It is what I looking for.. So I still could use FAN mosfet as master switch and pwm to control it .. Thanks
