TMC2208: not all UART devices recognized June 11, 2019 03:50PM |
#define X_SERIAL_TX_PIN 40 #define X_SERIAL_RX_PIN 63 #define X2_SERIAL_TX_PIN -1 #define X2_SERIAL_RX_PIN -1 #define Y_SERIAL_TX_PIN 59 #define Y_SERIAL_RX_PIN 64 #define Y2_SERIAL_TX_PIN -1 #define Y2_SERIAL_RX_PIN -1 #define Z_SERIAL_TX_PIN 19 //MS default 42 #define Z_SERIAL_RX_PIN 11 //MS default 65 #define Z2_SERIAL_TX_PIN -1 #define Z2_SERIAL_RX_PIN -1 #define E0_SERIAL_TX_PIN 42 //MS default 44 #define E0_SERIAL_RX_PIN 65 //MS default 66 #define E1_SERIAL_TX_PIN 44 //MS default -1 #define E1_SERIAL_RX_PIN 66 //MS default -1
21:18:19.600 : X Y Z E0 E1 21:18:19.634 : Enabled false false false false true 21:18:19.636 : Set current 800 800 800 800 800 21:18:19.667 : RMS current 1436 1436 1436 1436 795 21:18:19.697 : MAX current 2025 2025 2025 2025 1121 21:18:19.699 : Run current 25/31 25/31 25/31 25/31 25/31 21:18:19.700 : Hold current 12/31 12/31 12/31 12/31 12/31 21:18:19.731 : CS actual 0/31 0/31 0/31 0/31 12/31 21:18:19.760 : PWM scale 0 0 0 0 14 21:18:19.788 : vsense 0=.325 0=.325 0=.325 0=.325 1=.18 21:18:19.817 : stealthChop false false false false true 21:18:19.847 : msteps 256 256 256 256 16 21:18:19.875 : tstep 0 0 0 0 1048575 21:18:19.875 : pwm 21:18:19.878 : threshold 0 0 0 0 0 21:18:19.878 : [mm/s] - - - - - 21:18:19.907 : OT prewarn false false false false false 21:18:19.907 : OT prewarn has 21:18:19.910 : been triggered false false false false false 21:18:19.938 : off time 0 0 0 0 5 21:18:19.968 : blank time 16 16 16 16 24 21:18:19.968 : hysteresis 21:18:19.997 : -end -3 -3 -3 -3 2 21:18:20.025 : -start 1 1 1 1 3 21:18:20.025 : Stallguard thrs 21:18:20.027 : DRVSTATUS X Y Z E0 E1 21:18:20.056 : stst X 21:18:20.084 : olb 21:18:20.112 : ola 21:18:20.141 : s2gb 21:18:20.168 : s2ga 21:18:20.197 : otpw 21:18:20.225 : ot 21:18:20.253 : 157C 21:18:20.282 : 150C 21:18:20.310 : 143C 21:18:20.338 : 120C 21:18:20.339 : s2vsa 21:18:20.339 : s2vsb 21:18:20.347 : Driver registers: X = 0x00:00:00:00 21:18:20.353 : Y = 0x00:00:00:00 21:18:20.359 : Z = 0x00:00:00:00 21:18:20.365 : E0 = 0x00:00:00:00 21:18:20.372 : E1 = 0xC0:0C:00:00
Re: TMC2208: not all UART devices recognized June 12, 2019 04:17AM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: TMC2208: not all UART devices recognized June 12, 2019 06:04AM |
[SOLVED] TMC2208: not all UART devices recognized June 13, 2019 06:03PM |
Re: [SOLVED] TMC2208: not all UART devices recognized February 13, 2020 11:43AM |
