Z axis dont stop while printing
Posted by neillcl
June 18, 2019 09:28AM
hello everybody.
i build my 3d printer with endstops on min and max of each axis. all work fine when i move them by the printer screen or the pronterface on the laptop, the axis stop in time as the endstop bright.
when i start printing the hotend increase temperature and then the printer makes a checkup for the limits. goes to X in and then to max, goes to Y min and the to max, and with the z axis goes to Z max and everything is good, the problem is when it goes to Z min it doesnt stop even it it the endstop.
i Will be very thankfull if anyone can help me.
i use mega 2560, ramps 1.4 and marlin software
Re: Z axis dont stop while printing
June 18, 2019 09:45AM
Try to testing your End-Stops using M119 to determine if your end-stop are functioning.
Still not working would be to Upload your Marlin configuration_adv.h an configuration_adv.h to a share system like google drive, then attach a link to a post.
This way we can look at you configuration files.
June 18, 2019 09:59AM
they Works, only when is printing the z min dont stop.
[drive.google.com]
June 19, 2019 11:04PM
Roberts_Clif
I tested and they work fine
pronterface says: zmin Triggered
June 20, 2019 12:36AM
what type of axis does your machine have? in particular the Z axis
does the bed go up/down, where is 0 top or bottom of travel?
does the bed move in Y ie like a I3?
or something else?
