Wiring npn auto leveling sensor with ramps
Posted by 3dprintnow
August 11, 2020 07:31AM
Hello
I need to know how wiring blue LJ12A3-4-Z/BX npn auto leveling sensor with ramps 1.6
I see tutorials some resistors and other no
So I need to know how do it
Thank you
Edited 1 time(s). Last edit at 08/11/2020 09:56AM by 3dprintnow.
Re: Wiring npn auto leveling sensor with ramps
August 11, 2020 08:07AM
There's a lot of info about it on the web as you explained. What exactly are you having issues with? Are the tutorials not clear?
http://www.marinusdebeer.nl/
August 11, 2020 08:14AM
yes i need clear tutorial for how wire npn auto leveling sensor with ramps and this type need resistors or not
August 11, 2020 11:05AM
First you should try if the sensor works on 5 volts, sometimes they do. So I would say look for a schematic, get a power supply that supplies 5v and see if it triggers the sensor lighting up the LED on the top. Otherwise I suggest maybe getting an optocoupler or using a voltage divider. The tutorials that I've seen are very clear and I cannot make it any clearer:
[mertarauh.com]
August 11, 2020 11:14AM
Please check this image this sensor from 5 to 36 volt
August 11, 2020 02:15PM
3dprintnow
If it works at 5v then you do not need any resistors. You can just hook it up to your endstop connection. Just make sure you wire it correctly and also test if it works before you try to home the machine. If it doesn't work and it digs into your heated bed a lot can go wrong.
August 11, 2020 04:21PM
ok last thing can tell me diagram of cables connection for m npn sensor LJ12A3-4-Z/BX 5v-35v
