printer halted when just click on the file to print from sd card
Posted by 3dprintnow
September 01, 2020 08:42AM
hello
I get message printer halted when just click on the file to print from sd card
put it print well from the USB cable
printer halted when print from sd card
August 31, 2020 06:33PM
hello
Re: printer halted when just click on the file to print from sd card
September 01, 2020 08:57AM
Please don't create multiple topics in different forums about the same subject smiling smiley Thank you.
http://www.marinusdebeer.nl/
September 01, 2020 08:59AM
ok im sorry i do that because no one replay me from yasterday
September 01, 2020 11:27AM
You give zero information and expect mirracles...
How about some details?
Config files?
version of marlin?
small gcode examples that do this?
Edited 1 time(s). Last edit at 09/01/2020 11:27AM by Dust.
September 01, 2020 12:52PM
lcd i use 2004
marlin version 1.9
config attached
about g-code the same file and the same sd card working good with another printer
And this video to see what happen
[drive.google.com]
Edited 1 time(s). Last edit at 09/01/2020 01:07PM by 3dprintnow.
open | download - Configuration.h (72.2 KB)
September 01, 2020 03:08PM
I don't think this is an SD problem. It's probably an instruction in the beginning of the gcode file causing the printer to halt. It can have many reasons.
There might be something connected up wrongly or a short or an endstop not connected or something like a heating error. There can be many reasons. I would inspect the hardware first.
September 01, 2020 03:14PM
every hing is working because i can print from computer very good without any problem
September 02, 2020 07:54AM
an one can help me?
September 02, 2020 02:46PM
I think I had this problem when my voltage regulator on the Mega was broken. It would work fine with USB but using SD card it would Halt. With my machine the reason was because of the servo I was using. The servo was putting too much strain on the voltage regulator. But I honestly don't have a clue what it could be. What kind of setup is the machine? It must have something to do with the LCD panel or power supply.
September 03, 2020 12:16PM
i connect pin 44 with 5v in ramps its working good
thank you
