I am trying to connect BL Touch to RAMPS 1.6 without any luck. When i try to Jumper 5v and VCC pin ramps did not start and whole board was on sleep. If i remove the jumper then everything works fine. Did anyone face this issue. I really need BL Touch to work on my RAMPS 1.6 . Help me out.
I have the exact same problem. When I use a jumper on 5V and VCC my RAMPS 1.6 turn off, and when I take the jumper off the RAMPS turn on.
Does anyone has a solution?
