Error Printer halted. kill() called! HELP ME sad smiley
Posted by salva00
October 08, 2020 08:35AM
I have RAMPS V1.4 hooked up to an Arduino Mega (that was an anet A8), I've some issues with y axis of my printer (like in this video), and I tried to resolve that changing the current in the axis driver (DRV8825). Then I tried to send G28 to homing and this error was showed:
Connecting to: /dev/ttyUSB0
Changing monitoring state from "Offline" to "Opening serial port"
Connected to: Serial(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Changing monitoring state from "Opening serial port" to "Connecting"
Send N0 M110 N0*125
Send N0 M110 N0*125
Recv start
Recv echo:Marlin 1.1.9
Send N0 M110 N0*125
Recv echo: Last Updated: 2018-08-01 | Author: (Lorenzo, test config)
Recv echo:Compiled: Oct  8 2020
Recv echo: Free Memory: 5602  PlannerBufferBytes: 1232
Recv echo:Hardcoded Default Settings Loaded
Recv echo:  G21    ; (mm)
Recv echo:Filament settings: Disabled
Recv echo:  M200 D1.50
Recv echo:  M200 D0
Recv echo Steps per unit:
Recv echo:  M92 X266.67 Y266.67 Z1133.86 E500.00
Recv echo:Maximum feedrates (units/s):
Recv echo:  M203 X300.00 Y300.00 Z5.00 E25.00
Recv echo:Maximum Acceleration (units/s2):
Recv echo:  M201 X3000 Y3000 Z100 E10000
Recv echo:Acceleration (units/s2): P R T
Recv echo:  M204 P3000.00 R3000.00 T3000.00
Recv echo:Advanced: Q S T X Y Z E
Recv echo:  M205 Q20000 S0.00 T0.00 X10.00 Y10.00 Z0.30 E5.00
Recv echo:Home offset:
Recv echo:  M206 X0.00 Y0.00 Z0.00
Recv echo PID settings:
Recv echo:  M301 P22.20 I1.08 D114.00
Recv ok
Changing monitoring state from "Connecting" to "Operational"
Send N0 M110 N0*125
Recv ok
Send N1 M115*39
Recv FIRMWARE_NAME:Marlin 1.1.9 (Github) SOURCE_CODE_URL:[github.com] PROTOCOL_VERSION:1.0 MACHINE_TYPE:Marvin EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
Recv Cap SERIAL_XON_XOFF:0
Recv Cap:EEPROM:0
Recv Cap:VOLUMETRIC:1
Recv Cap:AUTOREPORT_TEMP:1
Recv Cap PROGRESS:0
Recv Cap PRINT_JOB:1
Recv Cap:AUTOLEVEL:0
Recv Cap:Z_PROBE:0
Recv Cap:LEVELING_DATA:0
Recv Cap:BUILD_PERCENT:0
Recv Cap SOFTWARE_POWER:0
Recv Cap:TOGGLE_LIGHTS:0
Recv Cap:CASE_LIGHT_BRIGHTNESS:0
Recv Cap:EMERGENCY_PARSER:0
Recv Cap:AUTOREPORT_SD_STATUS:0
Recv Cap:THERMAL_PROTECTION:1
Recv ok
Send M21
Recv echo:Unknown command: "M21"
Recv ok
Send M155 S2
Recv ok
Send G91
Recv ok
Send G1 Y100 F6000
Recv ok
Send G90
Recv ok
Send G91
Recv ok
Send G28 Z0
Recv  T:21.52 /0.00 @:0
Recv echo busy processing
Printer seems to support the busy protocol, will adjust timeouts and set busy interval accordingly
Recv  T:21.41 /0.00 @:0
Recv  T:21.84 /0.00 @:0
Recv  T:21.68 /0.00 @:0
Recv Error Printer halted. kill() called!
Changing monitoring state from "Operational" to "Error: Printer halted. kill() called!"
Send M112
Send N2 M112*35
Send N3 M104 T0 S0*34
Send N4 M140 S0*97
Changing monitoring state from "Error:  "Printer halted". kill() called!" to "Offline (Error: Printer halted. kill() called!)"
Connection closed, closing down monitor
Any suggestions?
Edited 5 time(s). Last edit at 10/08/2020 08:41AM by salva00.
Re: Error Printer halted. kill() called! HELP ME sad smiley
October 08, 2020 09:36AM
I would measure the V-Ref voltages on all DRV8825 drivers then post the results.
It does not appear that you are on the Y-Axis End-stop, though would still test all end-stops using M119.
October 08, 2020 11:13AM
All endstops work great, I'll report my driver vref for each axis:
- x axis: 0,14 V
- y axis: 2,13 V
- z axis: 1,57 V
October 08, 2020 05:17PM
Ok???
What are the specs for your Stepper motors.
Current Limit = VREF × 2
So, for example, if you have a stepper motor rated for 1 A, you can set the current limit to 1 A by setting the reference voltage to 0.5 V.
October 11, 2020 02:31PM
Roberts_Clif
Ok???
Sorry, I've been busy in these days. I'd share the steppers specs:
- Nominal power = 14W
- Nominal tension =3.96V
- Rated current = 0.9A
- Phase = 2
- Resistance = 4.4Ω ± 10%
- Temperature increase = 80K Max
- Insulation resistance = 100 MΩ Min. , 500VDC
October 11, 2020 08:15PM
you can hear there is plenty of current, issue is something else.
I would guess a broken wire between stepper motor and stepper driver.
Have you does basic tests? (before you try homing)
ie move X left and right with gcode or lcd., does it move left and right correctly?
move Y back and forward, does it move back and forward?
move Z up and down, does it move up and down?
and check endstops work with a M119 and manually test each end stop by sending M119 while not triggered, then holding down endstop with finger send second M119 and confirm it changes from open to triggered for every endstop.
Your error log shows G28 Z0, so it is trying to home Z, nothing to do with Y at all.
Edited 2 time(s). Last edit at 10/11/2020 08:21PM by Dust.
October 12, 2020 03:10AM
Dust
Before homing, I've done other tests with steppers and endstops but all worked perfectly. Only when I send the gcode for homing, the printer logs this error
October 12, 2020 05:54AM
while powered off move X and Y away from endstop
home each axis individually
ie Send machine a G28 X, verify if X homes
Then try Y with sending G28 Y, verify Y homes.
Then try Z with G28 Z, verify Z homes
also check your homing feed rates in you Configuration.h
eg
#define HOMING_FEEDRATE_XY (100*60)
#define HOMING_FEEDRATE_Z (4*60)
Edited 2 time(s). Last edit at 10/12/2020 05:57AM by Dust.
