Ramps change & D8 pin not working, maybe Arduino mega broken?
October 24, 2020 08:34AM
I had a ramps 1.3. (Marlin 2.0, Prusa i3 clone).
D10 was faulty so instead of using D10 & D8 i changed in pin_RAMPS.h in D9 and D8.
Extruder and bed worked just fine.
Some days ago I bought a Full Graphic Smart Controller (to use SD and not be in connection with the computer).
The SD didn't work.
So after several attempts I installed a new ramps 1.4.
SD is now working, reading gcodes in it.
Extruder mounted on D10 still not working. So I realized that the issue was not on the RAMPS but I think it's the Mega board.
Switched back to D9 and working.
The problem now is that D8 (the bed) is not working (while instead it was in RAMPS1.3.
The D9 (extruder) has 12V and the red led on the ramps is on.
D8 no voltage and led off.
If I put the bed on D9 (just to test), it heats and works.
SO:
1) can the D8 pin on the Mega board be gone?
2) is there any software that quickly run a diagnostics and says which (and if) pin is gone?
3) any suggestion to fix (D10 as mentioned was not working) or shall I buy a new mega?
THANKSSSSSS
Re: Ramps change & D8 pin not working, maybe Arduino mega broken?
October 24, 2020 09:31AM
yes dead/damaged pin happens a lot.
No there is no way to detect dead pins from firmware/software alone, you need additional hardware
Most basic test is a led and resistor use the blink sketch and set led pin to D8 (or other pin under test)
If its a dead pin you have to replace the mega2560 chip, or the entire board.
I wouldn't bother with a mega/ramps in this day and age. Get yourself a cheap 32 bit board.
Edited 1 time(s). Last edit at 10/24/2020 09:32AM by Dust.
