Correct pin outs for MKS Gen 1.4 with dual z motors and end stops and BL Touch
Posted by sportsracer
February 20, 2021 12:50PM
I have a dual z motor printer with dual z limit switches. I'm now trying to add a BL touch and am trying to figure out the configuration.
The limit switch for left z lead screw is connected to the X+ pin and the right limit switch is connected to the Z- pin.
Every BLTouch page I've seen connects it to the Z- pin. I think I can make this work by connecting the BLTouch to the Z+ pin by changing this value - I'm just not sure what the new value should be.
#define Z_MIN_PROBE_PIN 32 // Pin 32 is the RAMPS default
The pin_MKS_BASE_14.h file lists these pins, for Z+ do I use 19 or 45?
Limit Switches
| 2 | GND | X+ ( 2) PE4 ** Pin6 ** PWM2
| 3 | GND | X- ( 3) PE5 ** Pin7 ** PWM3
| 15 | GND | Y+ (15) PJ0 ** Pin63 ** USART3_RX
| 14 | GND | Y- (14) PJ1 ** Pin64 ** USART3_TX
| 19 | GND | Z+ (19) PD2 ** Pin45 ** USART1_RX
| 18 | GND | Z- (18) PD3 ** Pin46 ** USART1_TX
Re: Correct pin outs for MKS Gen 1.4 with dual z motors and end stops and BL Touch
February 20, 2021 04:51PM
Edited 1 time(s). Last edit at 02/20/2021 04:52PM by Dust.
February 21, 2021 11:46AM
So use 19. Also, the comment says 32 is the default, but I don't see 32 on the drawing. What is 32?
Edited 1 time(s). Last edit at 02/21/2021 11:48AM by sportsracer.
February 21, 2021 05:12PM
There is a undocumented port on that diagram. USB_MSD
pin D32 is on that port
February 23, 2021 05:55PM
Thank you.
