Ramps 1.6 problem
Posted by Hexentric
Ramps 1.6 problem
June 13, 2021 06:47AM
Two of my RAMPS 1.6 boards have suddenly broke
(one broke at first run and other broke after printing several weeks)
- bed is 200*200
- turns on when connected with usb
- two printers in similar setups/same settings works fine
- replacing mega 2560 did not help
- 12V setup
I found that F2 (i assume that is fuse) was not conducting on those broken ones and soldered it close.
I also redused bed heater cycle down to 50/255.
When heating bed it start to broke 15A fuse between board and psu.
Edited 2 time(s). Last edit at 06/13/2021 06:51AM by Hexentric.
Re: Ramps 1.6 problem
June 13, 2021 07:27AM
Since the heated bed is only a pcb, and the tracks are only covered in a thin layer of lacquer. make sure what ever you mounted the bed on hasn't rubbed through this layer, on top or bottom, causing a short
Edited 1 time(s). Last edit at 06/13/2021 07:28AM by Dust.
June 13, 2021 07:57AM
Element is under glass and measured R is 1,3 ohm when wires connected or disconnected (same as my few identical/unused heating elements)
Edited 1 time(s). Last edit at 06/13/2021 07:58AM by Hexentric.
June 13, 2021 08:32AM
well that circuit only goes through the fuse, the mosfet then the bed.
There has to he a short in there some where...
June 13, 2021 02:14PM
I assume it was heating cartridge.
I changed 20A fuse on power in and find that both beds heated up fine but hot ends had problems.
printer a
When heating hot end one mosfet (furthest from power in) got very hot.
Cartridge seems shorted and mosfet is constantly in conductive state.
printer b
Cartridge gives random R values and printer shows "heating failed" when heating hot end.
Mosfet seems to work because another cartridge heats up.
Cartridge in picture is similar as broken ones.
Edited 1 time(s). Last edit at 06/14/2021 06:51PM by Hexentric.
open | download - cartridge.jpg (352.3 KB)
June 13, 2021 09:16PM
Fuse 2 is the heated bed only.
June 14, 2021 06:55PM
well, after changing also hot end thermistors both printers work
