12V 20 ohm Heating Mat
Posted by unialpha
September 14, 2021 10:44AM
Hey guys, I'm having trouble when connecting this heating mat to my printer:
[uk.rs-online.com]
it's 12V so I connect it directly to the D8 port in the RAMPS board. The problem is that although it should be able to reach 300ºC according to the datasheet, I am only able to heat it up to 50ºC with the printer. I think it might be do to its resistance (20 ohm), since heating cartidges are usually 10-15 ohm, so this mat needs more current. In case my hypothesis is right, is there a way to supply it with more current? I mean with the RAMPS itself, I know I could install an external mosfet.
#define PID_MAX is already set to 255
Thank you smiling smiley
Edited 1 time(s). Last edit at 09/14/2021 10:44AM by unialpha.
rq3
Re: 12V 20 ohm Heating Mat
September 14, 2021 11:10AM
unialpha
[uk.rs-online.com]
The D8 RAMPS port can output 11 amps at 12 volts, so that's not the problem. The problem is that your mat has a resistance of 20 ohms, so it draws only 12/20=0.6 amps. 0.6Ax12volts=7.2 watts.
About as much as a Christmas tree bulb. 50C sounds about right. It's a silicone mat (apparently) so it should be able to survive exposure to 300C, but it isn't likely to get anywhere near that temperature running on 12 volts.
