Hi all,
suddenly the RepRap Full Graphic Smart Controller Board on my Fabricator Mini 1.5 started to flash the backlight and beep in roughly a one second rhythm. A few minutes earlier it was still working. Since it worked before and the cables on both sides have keyed connectors, I can rule out that the cables are connected wrong.
The only thing I noticed before the failure was that the display itself was showing a low contrast section in the middle of the display that has appeared there a while ago and the backlight might have been a little bright.
What could cause this?
Best regards,
Reiner
