I burned Arduino on ramps 1.6 - Dunno why...
Posted by Chipa
February 06, 2022 05:21AM
I am doing my 3D printer project.
i wanted to set on my 3d printer bl-touch.  i short  vcc 5v with jumper on mega 1.6. The board turned off immediately and my arduino just burned in 3 sec.
Can someone explain what I did wrong ? confused smileyconfused smiley
open | download - Untitled-2.jpg (257.5 KB)
Re: I burned Arduino on ramps 1.6 - Dunno why...
February 06, 2022 05:55AM
There must be a short on the 5v servo rail somewhere.
check resistance from 5v pin to gnd
February 06, 2022 06:34AM
Dust
I checked the resistance and it is 0 zero .
Seems like something is wrong right?
What could it be? confused smiley
open | download - IMG_1529.jpg (364 KB)
February 06, 2022 07:06AM
that is very wrong
the 5v pin should only connect to 5v pins on servo plug
There is either a pcb fault, for a solder bridge somewhere.
Finding it will be nearly impossible
February 06, 2022 07:10AM
From this thread
[reprap.org]
These boards seem to have a design fault
February 06, 2022 08:25AM
Dust
that is very wrong
Thanks for info. is somewere avalable Ramps 1.6 PCB DESIGN ? i wanna follow where is 5V trace going...eye rolling smiley
February 06, 2022 08:31AM
Dust
From this thread
[reprap.org]
Is that 1.6 ramps are broken ? or just every ramps is the same?
February 06, 2022 09:00AM
only that brand of 1.6 that I know of. I have not had this issue with ramp 1.4's
take a high res image of bottom of 1.6 see if anything is obvious
Edited 2 time(s). Last edit at 02/09/2022 12:55AM by Dust.
VDX
February 06, 2022 10:17AM
... if it's onla a "small" short, you can try to locate it by high "overcurrent" -- maybe it will burn/explode the short, so you can see where ...
Viktor
February 06, 2022 10:48AM
Dust
only 1.6 that I know of. I have not had this issue with ramp 1.4's
take a high res image of bottom of 1.5 see if anything is obvious
open | download - IMG_1543.jpg (611.3 KB)
VDX
February 06, 2022 12:10PM
... is the PCB 2- or 4-layers?
Viktor
February 06, 2022 12:21PM
VDX
i did already (24v) by mistake. but... i just burn only arduino grinning smiley
Edited 2 time(s). Last edit at 02/06/2022 12:26PM by Chipa.
February 06, 2022 12:25PM
VDX
i am not shure but i think it is 4 layer.
VDX
February 06, 2022 04:54PM
... then good luck with finding the error ... or, better find a different board eye rolling smiley
Viktor
February 06, 2022 06:07PM
at the back of the reset switch and under the servo plugs you can clearly see the trace that is the 5v line.
But it looks like that trace goes to one of the gnded mounting pins of the reset switch (but the image is not very clear in that area)
February 06, 2022 06:08PM
I will never buy Arduino ramps anymore for 3D printers. I have my own project and I wanted to just test on cheap board, but I spent more than 32 bit proper boards . and it was only pain...
Ramps 1.6 are so broken. and it is not happening only to me. I see many people have the same issue.
Im fairly sure its 2 layers. Most ramps are
February 06, 2022 06:15PM
Dust
is that better?
open | download - IMG_1545.jpg (332.4 KB)
February 07, 2022 03:01AM
ok so it is not gnded there.. was just the picture.
If this was my board, I would cut the track on the red line as pictured
Then test which side has the short to gnd, Either the +5v pin on the servo plug end or just the vcc/5v jumper end.
give you an idea where to look.
If short is not on the servo plugs side I would just ignore it. (apart from curiosity)
then all you need to do is connect +5v on the servo plug to any vcc nearby with a jumper wire.
If the short is on the servo end... next step would be to un solder the servo pins and examine what is on the top of the pcb under the where the pins where
Edited 4 time(s). Last edit at 02/07/2022 03:15AM by Dust.
February 07, 2022 09:02AM
Dust
[attachment 119158 cut_here.jpg]
i am planing to unsolder everything as possible.
i will post new images later.
thank for helping and advice..thumbs upsmileys with beer
February 08, 2022 05:40AM
I desoldered the whole board and its sanded now . grinning smiley
and i think i found why 5V and Ground have shorts..
I think there is a short where I highlighted.
Edited 1 time(s). Last edit at 02/08/2022 06:02AM by Chipa.
open | download - opaaa.jpg (987.4 KB)
February 08, 2022 07:00AM
Over kill, but nice!
Yes that looks like the short to me. and a bad one.
Cutting the track like I suggested should work, or drill out that via.
Can I use your images?, ill add a note to the reprap wiki about this issue
February 08, 2022 07:10AM
Dust
I cut already this track on this board and everything is okay.
Dust
yes! no problemsmileys with beer
VDX
February 08, 2022 07:16AM
... good (laborious) find! smileys with beer
Viktor
February 08, 2022 08:44AM
Ive added a Warning to reprap wiki page [reprap.org]
Its not as prominent as I would like, but the markup laguage was really fighting with me..
