Ramps 1.4 and Marlin - D8 and D9 Linked
May 03, 2022 11:39AM
Hello,
Have a bit of an issue with my ramps setup after updating firmware.
If I turn my cooling fan on (via D9) or turn my heated bed on (D8) the other pin will also turn on. Its almost as if they are linked.
I have check and I am using the EFB motherboard config in marlin, pins.h is referring to the right board, and in the ramps.h the D8 refers to 8, D9 to 9. The FAN_pin also points to D9 and the heat bed pin points to D8.
I have replaced my Ramps 1.4 board and replaced the MOSFETT. I do not think this is a hardware issue. The activity LEDS for D8 and D9 will light up when either is triggered in software.
I cannot see any loose wiring or issues on the board itself.
Can anyone help?
Many thanks
open | download - pins_RAMPS.h (15.9 KB)
open | download - pins.h (28.9 KB)
open | download - Configuration.h (72.2 KB)
Re: Ramps 1.4 and Marlin - D8 and D9 Linked
May 03, 2022 12:40PM
It appears that your configurations are good.
Normally I add MOSFET_D_PIN for E1 or FAN1_PIN
#ifndef MOSFET_D_PIN
  #define MOSFET_D_PIN      7 //This adds E1 or 2nd fan
#endif
#ifndef RAMPS_D8_PIN
  #define RAMPS_D8_PIN      8
#endif
#ifndef RAMPS_D9_PIN
  #define RAMPS_D9_PIN      9
#endif
#ifndef RAMPS_D10_PIN
  #define RAMPS_D10_PIN    10
#endif
Do you have to Original source code, can you post the Configuration.h, Configuration_adv.h and pins_RAMPS.h for the working original firmware I will look see what happened.
Edited 1 time(s). Last edit at 05/03/2022 11:34PM by Roberts_Clif.
May 04, 2022 06:19AM
I feel like a right idiot, it was a hardware issue after all!
The top of the fan mosfet was leaning over and touching the heatbed mosfett, I have leant it back and everything is fine, thanks for all the reply!
May 04, 2022 08:32AM
I hate it stuff like that happens, my controller had a line on mosfets
I placed a piece if bar aluminum connecting the mosfets with TO220 kits Photos below
