Ramps 1.6 and 3 pin Fan for Cooling June 05, 2023 07:48AM |
Re: Ramps 1.6 and 3 pin Fan for Cooling June 05, 2023 08:11AM |
Admin Registered: 15 years ago Posts: 7,321 |
Re: Ramps 1.6 and 3 pin Fan for Cooling June 06, 2023 06:02AM |
Re: Ramps 1.6 and 3 pin Fan for Cooling June 06, 2023 07:38AM |
Re: Ramps 1.6 and 3 pin Fan for Cooling June 08, 2023 10:24AM |
If I will not be using hotend and heated bed, can I connect 2-pin fans to these outputs?Quote
Dust
RAMPS uses 2 wire fans.
They PWM the power to change the speed. Ie then only use +V (red) and GND (black) wires.
Fans have to be connected via a mosfet to be software controlled.
A stock ramps has 3 mosfets, used for hotend, heated bed and part cooling fan.
Re: Ramps 1.6 and 3 pin Fan for Cooling June 08, 2023 07:33PM |
