Ramps 1.6 and 3 pin Fan for Cooling
June 05, 2023 07:48AM
Dear RepRap Forum members,
I am using RAMPS 1.6 with 4 TM2208 drivers. I want to cool these drivers with a 3 pin (red, black, white) fan. How should I connect the fan and run it?
Best regards.
bkarpuz
Re: Ramps 1.6 and 3 pin Fan for Cooling
June 05, 2023 08:11AM
RAMPS uses 2 wire fans. They PWM the power to change the speed. Ie then only use +V (red) and GND (black) wires
Fans have to be connected via a mosfet to be software controlled.
A stock ramps has 3 mosfets, used for hotend, heated bed and part cooling fan.
So step 1 is add more mosfets eg by using a RAMPS RRD Fan Extender
Step 2 is to configure a Controller Fan. this fan turns on when heating mosfets are active or when stepper drivers are active.
Enable #define USE_CONTROLLER_FAN
Add the mosfet pin #define CONTROLLER_FAN_PIN {pin number}
Edited 6 time(s). Last edit at 06/05/2023 08:43AM by Dust.
June 06, 2023 06:02AM
Dust
Part cooling is the part being printed, right?
Dust
How can I connect this to RAMPS 1.6?
Thank you very much Dust.
June 06, 2023 07:38AM
"Part cooling is the part being printed, right?" yes
That mosfet extension plugs into the servo plugs
June 08, 2023 10:24AM
Dust
They PWM the power to change the speed. Ie then only use +V (red) and GND (black) wires.
If I will not be using hotend and heated bed, can I connect 2-pin fans to these outputs?
June 08, 2023 07:33PM
Yes
