Todd900
. Do I need any type of current limiting device ,resisters, etc., in between? can I just hook the positive straight up to the vcc jumper pin? Also, where exactly do I hook these up to? Do I put the positive on the VCC and just hook the ground anywhere on the servo pin ground?
Noting inbetween. Positive of the converter just to the sensor; don't connect it to the 5V on the board. Ground can be anywhere; these buck converters have a common ground, so it's the same ground your ramps and atmega uses.
Other option is using the output to drive your atmega and ramps; D1 on the ramps has to be removed for this, and i think a connetion heas to be made from atmega's 5 volt out to the atmega 5v in.
