Anet A8+ resurrection - Ramps1.6 on Mega2560 April 26, 2026 09:50AM |
Re: Anet A8+ resurrection - Ramps1.6 on Mega2560 April 26, 2026 10:11PM |
Admin Registered: 15 years ago Posts: 7,337 |
#ifndef MOSFET_A_PIN #define MOSFET_A_PIN 10 #endif #ifndef MOSFET_B_PIN #define MOSFET_B_PIN 9 #endif #ifndef MOSFET_C_PIN #define MOSFET_C_PIN 8 #endif
#define HEATER_0_PIN MOSFET_A_PIN
#define HEATER_BED_PIN MOSFET_C_PIN
#define FAN0_PIN MOSFET_B_PIN
// // AUX1 5V GND D1 D0 // 2 4 6 8 // 1 3 5 7 // 5V GND A3 A4 // #define AUX1_05 57 // (A3) #define AUX1_06 1 // TX0 #define AUX1_07 58 // (A4) #define AUX1_08 0 // RX0 // // AUX2 GND A9 D40 D42 A11 // 2 4 6 8 10 // 1 3 5 7 9 // VCC A5 A10 D44 A12 // #define AUX2_03 59 // (A5) #define AUX2_04 63 // (A9) #define AUX2_05 64 // (A10) #define AUX2_06 40 #define AUX2_07 44 #define AUX2_08 42 #define AUX2_09 66 // (A12) #define AUX2_10 65 // (A11)
#define X_DIR_PIN 55 // (A1) #define Y_ENABLE_PIN 56 // (A2)
**Arduino Mega 2560 PIN mapping table** | Pin Number | Pin Name | Mapped Pin Name | | ---------- | ------------------------ | ------------------------------ | | 1 | PG5 ( OC0B ) | Digital pin 4 (PWM) | | 2 | PE0 ( RXD0/PCINT8 ) | Digital pin 0 (RX0) | | 3 | PE1 ( TXD0 ) | Digital pin 1 (TX0) | | 4 | PE2 ( XCK0/AIN0 ) | | | 5 | PE3 ( OC3A/AIN1 ) | Digital pin 5 (PWM) | | 6 | PE4 ( OC3B/INT4 ) | Digital pin 2 (PWM) | | 7 | PE5 ( OC3C/INT5 ) | Digital pin 3 (PWM) | | 8 | PE6 ( T3/INT6 ) | | | 9 | PE7 ( CLKO/ICP3/INT7 ) | | | 10 | VCC | VCC | | 11 | GND | GND | | 12 | PH0 ( RXD2 ) | Digital pin 17 (RX2) | | 13 | PH1 ( TXD2 ) | Digital pin 16 (TX2) | | 14 | PH2 ( XCK2 ) | | | 15 | PH3 ( OC4A ) | Digital pin 6 (PWM) | | 16 | PH4 ( OC4B ) | Digital pin 7 (PWM) | | 17 | PH5 ( OC4C ) | Digital pin 8 (PWM) | | 18 | PH6 ( OC2B ) | Digital pin 9 (PWM) | | 19 | PB0 ( SS/PCINT0 ) | Digital pin 53 (SS) | | 20 | PB1 ( SCK/PCINT1 ) | Digital pin 52 (SCK) | | 21 | PB2 ( MOSI/PCINT2 ) | Digital pin 51 (MOSI) | | 22 | PB3 ( MISO/PCINT3 ) | Digital pin 50 (MISO) | | 23 | PB4 ( OC2A/PCINT4 ) | Digital pin 10 (PWM) | | 24 | PB5 ( OC1A/PCINT5 ) | Digital pin 11 (PWM) | | 25 | PB6 ( OC1B/PCINT6 ) | Digital pin 12 (PWM) | | 26 | PB7 ( OC0A/OC1C/PCINT7 ) | Digital pin 13 (PWM) | | 27 | PH7 ( T4 ) | | | 28 | PG3 ( TOSC2 ) | | | 29 | PG4 ( TOSC1 ) | | | 30 | RESET | RESET | | 31 | VCC | VCC | | 32 | GND | GND | | 33 | XTAL2 | XTAL2 | | 34 | XTAL1 | XTAL1 | | 35 | PL0 ( ICP4 ) | Digital pin 49 | | 36 | PL1 ( ICP5 ) | Digital pin 48 | | 37 | PL2 ( T5 ) | Digital pin 47 | | 38 | PL3 ( OC5A ) | Digital pin 46 (PWM) | | 39 | PL4 ( OC5B ) | Digital pin 45 (PWM) | | 40 | PL5 ( OC5C ) | Digital pin 44 (PWM) | | 41 | PL6 | Digital pin 43 | | 42 | PL7 | Digital pin 42 | | 43 | PD0 ( SCL/INT0 ) | Digital pin 21 (SCL) | | 44 | PD1 ( SDA/INT1 ) | Digital pin 20 (SDA) | | 45 | PD2 ( RXDI/INT2 ) | Digital pin 19 (RX1) | | 46 | PD3 ( TXD1/INT3 ) | Digital pin 18 (TX1) | | 47 | PD4 ( ICP1 ) | | | 48 | PD5 ( XCK1 ) | | | 49 | PD6 ( T1 ) | | | 50 | PD7 ( T0 ) | Digital pin 38 | | 51 | PG0 ( WR ) | Digital pin 41 | | 52 | PG1 ( RD ) | Digital pin 40 | | 53 | PC0 ( A8 ) | Digital pin 37 | | 54 | PC1 ( A9 ) | Digital pin 36 | | 55 | PC2 ( A10 ) | Digital pin 35 | | 56 | PC3 ( A11 ) | Digital pin 34 | | 57 | PC4 ( A12 ) | Digital pin 33 | | 58 | PC5 ( A13 ) | Digital pin 32 | | 59 | PC6 ( A14 ) | Digital pin 31 | | 60 | PC7 ( A15 ) | Digital pin 30 | | 61 | VCC | VCC | | 62 | GND | GND | | 63 | PJ0 ( RXD3/PCINT9 ) | Digital pin 15 (RX3) | | 64 | PJ1 ( TXD3/PCINT10 ) | Digital pin 14 (TX3) | | 65 | PJ2 ( XCK3/PCINT11 ) | | | 66 | PJ3 ( PCINT12 ) | | | 67 | PJ4 ( PCINT13 ) | | | 68 | PJ5 ( PCINT14 ) | | | 69 | PJ6 ( PCINT 15 ) | | | 70 | PG2 ( ALE ) | Digital pin 39 | | 71 | PA7 ( AD7 ) | Digital pin 29 | | 72 | PA6 ( AD6 ) | Digital pin 28 | | 73 | PA5 ( AD5 ) | Digital pin 27 | | 74 | PA4 ( AD4 ) | Digital pin 26 | | 75 | PA3 ( AD3 ) | Digital pin 25 | | 76 | PA2 ( AD2 ) | Digital pin 24 | | 77 | PA1 ( AD1 ) | Digital pin 23 | | 78 | PA0 ( AD0 ) | Digital pin 22 | | 79 | PJ7 | | | 80 | VCC | VCC | | 81 | GND | GND | | 82 | PK7 ( ADC15/PCINT23 ) | Analog pin 15 / Digital pin 69 | | 83 | PK6 ( ADC14/PCINT22 ) | Analog pin 14 / Digital pin 68 | | 84 | PK5 ( ADC13/PCINT21 ) | Analog pin 13 / Digital pin 67 | | 85 | PK4 ( ADC12/PCINT20 ) | Analog pin 12 / Digital pin 66 | | 86 | PK3 ( ADC11/PCINT19 ) | Analog pin 11 / Digital pin 65 | | 87 | PK2 ( ADC10/PCINT18 ) | Analog pin 10 / Digital pin 64 | | 88 | PK1 ( ADC9/PCINT17 ) | Analog pin 9 / Digital pin 63 | | 89 | PK0 ( ADC8/PCINT16 ) | Analog pin 8 / Digital pin 62 | | 90 | PF7 ( ADC7/TDI ) | Analog pin 7 / Digital pin 61 | | 91 | PF6 ( ADC6/TDO ) | Analog pin 6 / Digital pin 60 | | 92 | PF5 ( ADC5/TMS ) | Analog pin 5 / Digital pin 59 | | 93 | PF4 ( ADC4/TCK ) | Analog pin 4 / Digital pin 58 | | 94 | PF3 ( ADC3 ) | Analog pin 3 / Digital pin 57 | | 95 | PF2 ( ADC2 ) | Analog pin 2 / Digital pin 56 | | 96 | PF1 ( ADC1 ) | Analog pin 1 / Digital pin 55 | | 97 | PF0 ( ADC0 ) | Analog pin 0 / Digital pin 54 | | 98 | AREF | Analog Reference | | 99 | GND | GND | | 100 | AVCC | VCC |
Re: Anet A8+ resurrection - Ramps1.6 on Mega2560 April 28, 2026 09:14AM |
