driving 2 motors on Y axis on ramps 1.3
Posted by robtbldr
July 27, 2011 11:55PM
Hi. Am new here but lurking for a long time. I just wanted to know if it was possible to run 2 motors on the y axis instead of the z axis without too much of a problem. I'm running ramps 1.3. Thanks for the input.
Re: driving 2 motors on Y axis on ramps 1.3
July 28, 2011 06:47PM
The only difference between the Y and Z axis on Ramps 1.3 is that the Z axis has 2 motor connectors wired in parallel. You'll have to assemble a splitter, but other than that, running 2 motors on the Y axis would work just fine.
You also could just edit Pins.h, and swap the Y and Z axis pins around.
