Hi Mike,
Thanks, It's running a quite modified GEN-7 V1.5 electronics. The main reason for making it is to print parts for my work, support brackets, insulators, that sort of thing. All the stuff with fiddly shapes that are reasonably easy to draw but a pain the ass to make on the milling machine. So far though it's mostly been making upgraded parts for it's self, and it does need a new heated bed because the current one was made using some brass and ceramic resistors I had laying around and 60W isn't enough with the fan on it. The upgrade I've got the parts for but not built yet will be a 2-circuit bed, 80+50W on a 5mm thick aluminium plate, with ceramic insulation backing. I'm also going to tap the fixing bolts into the bed so that they sit completely flush to the surface which should get me an extra 20mm of so of X-axis travel
Steve
Prussa i2 Comissioned 4-Nov-2013
Bitcoin : 1Jcrg5czBtNfKyS4sCjFAamJTcSYdTGk9h
