Re: Contacts info for a get together May 17, 2012 05:42PM |
Re: Contacts info for a get together May 19, 2012 08:32AM |
Re: Contacts info for a get together May 24, 2012 02:00PM |
Re: Contacts info for a get together June 04, 2012 02:32PM |
Re: Contacts info for a get together June 06, 2012 07:44AM |
Re: Contacts info for a get together June 06, 2012 09:37AM |
Re: Contacts info for a get together June 06, 2012 11:02AM |
- I can make any days except 21/22 July.|
Re: Contacts info for a get together June 06, 2012 11:17AM |
Re: Contacts info for a get together June 07, 2012 07:06PM |
Re: Contacts info for a get together June 08, 2012 04:48AM |
Anonymous User
Re: Contacts info for a get together June 09, 2012 04:47PM |
Re: Contacts info for a get together June 10, 2012 06:26AM |
Re: Contacts info for a get together June 10, 2012 02:21PM |
- I think it's simply down to the design of the Arcol and vast majority of hotend designs that try (and succeed to varying degrees) to apply sufficient force along the length of the PTFE tube to create an acceptable seal. I'll share the design, but currently too tied up with other stuff to spare the time right now - essentially I want to try clamping the PTFE AT the junction - i.e. removing the compressive load over the entire tube length and applying it locally - using a butt-flange (poss with some small flare/taper for alignment) and at the hotend proper, seal it with a 37deg flared fitting style compressive joint used extensively in aviation and many other industries.
Re: Contacts info for a get together June 11, 2012 05:21AM |
Re: Contacts info for a get together June 11, 2012 05:50AM |
Re: Contacts info for a get together June 11, 2012 06:57AM |
Re: Contacts info for a get together June 11, 2012 07:16AM |
Anonymous User
Re: Contacts info for a get together June 11, 2012 02:38PM |
Re: Contacts info for a get together June 11, 2012 05:19PM |
Re: Contacts info for a get together June 11, 2012 08:59PM |
Re: Contacts info for a get together June 18, 2012 10:23AM |
Re: Contacts info for a get together June 18, 2012 12:02PM |
Anonymous User
Re: Contacts info for a get together June 18, 2012 03:44PM |
Re: Contacts info for a get together June 18, 2012 06:51PM |
Re: Contacts meeting in August !! June 19, 2012 11:57AM |
Re: Contacts meeting in August !! June 19, 2012 12:12PM |
Re: Contacts meeting in August !! June 19, 2012 12:54PM |
so its alive for Saturday|
Anonymous User
Re: Contacts meeting in August !! June 19, 2012 05:56PM |
Re: Contacts meeting in August !! June 20, 2012 06:42AM |
Re: Contacts meeting in August !! June 20, 2012 08:39AM |
