March 7 Meetup
Posted by: Sublime ()
Date: February 28, 2012 01:24AM
Next meeting Wednesday March 7 @ 7pm Boston Pizza Walnut grove.
If you have a better location or day just speak up.
New comers are always welcome.
Edited 1 time(s). Last edit at 03/10/2012 07:10PM by Sublime.
Re: March 7 Meetup smileys with beer
Posted by: johnbiehler ()
Date: February 28, 2012 01:00PM
I may not be able to make it as I'm flying to Austin the next morning. Put me down as a maybe (assuming I get all packed in time).
John
Edited 1 time(s). Last edit at 02/28/2012 02:22PM by johnbiehler.
[johnbiehler.com]
Date: February 28, 2012 06:59PM
Nevermind...I can make it now...my flight isn't until later in the afternoon on Thursday.
[johnbiehler.com]
Posted by: ECSuyu ()
Date: February 29, 2012 04:23PM
Hopefully I can make it, caught the flu. Will update you guys as it gets close
Date: March 04, 2012 04:05AM
Looks like Im going to be good to go for this meet smiling smiley
edit: is it just me or does my signature not show up. if it doesnt what format do you guys put it in
Edited 1 time(s). Last edit at 03/04/2012 04:06AM by ECSuyu.
Date: March 04, 2012 02:09PM
I see no signature on your post.
For url's you need a square bracket then url=http://........... (space) "the name you want displayed" (no quotes) then another square bracket
The cut off line in my signature is just a really long underscore.
Date: March 04, 2012 06:01PM
ya weird, I have the php code in my signature profile in control but it doesnt show
Posted by: bobby_rep ()
Date: March 05, 2012 03:17AM
I'm going to try and make it, but my students have finals this week so I may be bogged down in marking sad smiley
Date: March 05, 2012 03:19AM
As an aside.. Here is my latest print attempt... Getting closer, but so much minor tweaking required... can't wait for spring break so I can devote some serious time to figuring out the issues..
Date: March 05, 2012 03:34AM
I would say you need to cool the upper part of the hotend from the look of it. Do you have a fan blowing across it yet?
I would also guess that you need to purge the hotend a LOT more before starting the print. You want the filament coming out like a smaller version of what is going in not runny or syrupy.
Edited 1 time(s). Last edit at 03/05/2012 03:48AM by Sublime.
Date: March 05, 2012 01:10PM
I think its a combination of pinching the filament too tightly against the hob/ or too loose and stripping it or the hotend is jamming which is unlikely unless there is something in the filament that caused it to jam. I can print ABS at 220C without any issues with no fan, but long prints (3+ hrs) will eventually cause issues for me as the heat travels up.
But Bobby, If you want the start and end .gcodes I use let me know. It ill pre-purge the nozzle for you, and once the print finishes move away.
___________________________________________________
Kreativ-e
Tinkerine Studio
Date: March 05, 2012 02:16PM
Hey guys, Thanks for the tip Brad. I had a fan connected to stabilize my psu but it was a bit big. I have now mounted the fan this morning. Because it's a little big it's tilted up but it hits the black part of the jhead for sure. Not the tipt though. See the pic below.. let me know if it need adjusting in your guys opinion.
The start and end g.codes for purging would be great Eugene.. I'll add them to the slicer commands so I dont have to do it. Thanks
I think it may also be an issue with my extruder steps... I'll do the measurement you suggested hopefully tonight
Date: March 05, 2012 02:53PM
I was assuming you were printing PLA since you have a bed covered in blue tape which is why I suggested the fan (Must have for PLA) but if you are printing ABS like Eugene then it is not as required.
I would also agree with Eugene that it could be a hobbed bolt issue, either too tight or too loose. But I have never really found the tension very important other than to have it tight.
But most of all CALIBRATE your E-steps-per-mm. No reason to even try printing before that point unless you like to waste time and plastic.
Posted by: gonzo007 ()
Date: March 05, 2012 03:47PM
Another 2 months and I will be able to come back out to these meets. Have a good one guys.
Colin
Date: March 05, 2012 05:08PM
Thanks Brad, I think I have my e-steps right... I think my problem is the kapton versus blue tape.. so glad I had the Canadian Tire 5$ scratch coupon so the tape only cost me 99 cents haha. Either I'll steal kapton from Eugene next week.. or I'll wait ill my 30mm wide roll comes in..I have a roll of the thin stuff.. if I get really desperate I'll lay it down one strip at a time... or 'con'vince the wife to...
Date: March 05, 2012 05:11PM
Have you worked on your prusa at all Colin?
[johnbiehler.com]
Posted by: ghostling ()
Date: March 05, 2012 09:52PM
if i didn't suddenly have to redo the plumbing and put tile around my bathtub i'd come to this meet. but i've got broken things to fix and i like to shower... so I probably won't make it this time. sad smiley
but i do have my printer working and printing things in ABS.. not large parts tho, because my heated bed isn't hot enough to keep the ABS from warping. ordered some PLA from mixshop, but have to wait for them to replenish their stock before they ship. looking forward to a day i can meet some fellow reprappers.
Date: March 06, 2012 07:45PM
To be honest no. Between work, family and getting our townhome ready to list there really hasn't been time. Once the place is sold I will get back on it. Also not being able to come out to meets doesn't help with me getting stuff built.
Colin
Date: March 07, 2012 02:06AM
I think I'll be good enough to go to the meet tomorrow! I'll see everyone then.
Kreativ-e
Tinkerine Studio
Date: March 07, 2012 06:19PM
Posted by: broncosis ()
Date: March 07, 2012 08:13PM
hey guys sorry I wont be there
but I have good news most of the parts are here
just waiting on a few alegro's and my solder paste
Date: March 08, 2012 06:25PM
nice! cant wait to get all my electronics for the prusa. Rob are you pre testing the stepsticks to see if they all work first?
Kreativ-e
Tinkerine Studio
Date: March 08, 2012 09:06PM
well I will do as much testing as I can
I have a pursa waiting for electronics too
so I will be able to do a little testing
but if your in a rush I can smack a untested one up
once the solder paste gets here
Date: March 08, 2012 09:08PM
where do u get your solder paste? it's not that expensive to just buy them locally at RP electronics.
Date: March 08, 2012 10:39PM
I ordered it online Rp is a pain to get to during the week for me I work almost 12 hours a day and I commute in the the company van
but it should be here anytime
Date: March 09, 2012 02:07AM
I was going to offer my help in testing them if you didnt have your electronic once my 2nd RAMPS gets here but let me know if you need help with it regardless.
Kreativ-e
Tinkerine Studio
This forum powered by Phorum.
