STB`s Graphik LCD und Rumba? 10. June 2013 03:18 |
Registrierungsdatum: 12 Jahre zuvor Beiträge: 1.807 |
Re: STB`s Graphik LCD und Rumba? 10. June 2013 07:01 |
Registrierungsdatum: 13 Jahre zuvor Beiträge: 212 |
Re: STB`s Graphik LCD und Rumba? 10. June 2013 09:05 |
Re: STB`s Graphik LCD und Rumba? 10. June 2013 11:18 |
Re: STB`s Graphik LCD und Rumba? 11. June 2013 09:07 |
Re: STB`s Graphik LCD und Rumba? 21. June 2013 14:46 |
Re: STB`s Graphik LCD und Rumba? 23. June 2013 11:05 |
Registrierungsdatum: 13 Jahre zuvor Beiträge: 258 |
Re: STB`s Graphik LCD und Rumba? 24. June 2013 13:21 |
/* On some broken versions of the Sanguino libraries the pin definitions are wrong, which then needs SDSS as pin 24. But you better upgrade your Sanguino libraries! See #368. */
//#define SDSS 24
#ifdef ULTRA_LCD
#ifdef NEWPANEL
//we have a buzzer installed
#define BEEPER 37
//LCD Pins
#ifdef DOGLCD
// Pins for DOGM SPI LCD Support
#define DOGLCD_A0 23 // RAMPS AUX-4 Pin 16
#define DOGLCD_CS 17 // RAMPS AUX-4 Pin 17
// GLCD features
#define LCD_CONTRAST 1
// Uncomment screen orientation
// #define LCD_SCREEN_ROT_0
// #define LCD_SCREEN_ROT_90
#define LCD_SCREEN_ROT_180
// #define LCD_SCREEN_ROT_270
#else // standard Hitachi LCD controller
#define LCD_PINS_RS 4
#define LCD_PINS_ENABLE 17
#define LCD_PINS_D4 30
#define LCD_PINS_D5 29
#define LCD_PINS_D6 28
#define LCD_PINS_D7 27
#endif
//The encoder and click button
#define BTN_EN1 35 // RAMPS Aux-4 Pin 10 must be a hardware interrupt pin
#define BTN_EN2 33 // RAMPS Aux-4 Pin 11 must be hardware interrupt pin
#define BTN_ENC 31 // RAMPS Aux-4 Pin 12 the switch
//not connected to a pin
#define SDCARDDETECT 49 // RAMPS Aux-3 Pin 2
//from the same bit in the RAMPS Newpanel define
//encoder rotation values
#define encrot0 0
#define encrot1 2
#define encrot2 3
#define encrot3 1
#define BLEN_C 2
#define BLEN_B 1
#define BLEN_A 0
#endif //Newpanel
#endif //Ultipanel
#endif
// An RAMPS Aux-3 Pin 18 hängt der Switch für den Lüfter, den musst Du direkt in der RAMPS Section der pins.h ändern.
#define FAN_PIN 16
Re: STB`s Graphik LCD und Rumba? 19. August 2013 15:24 |
#define BTN_EN1 31 // RAMPS Aux-4 Pin 12 must be a hardware interrupt pin
#define BTN_ENC 35 // RAMPS Aux-4 Pin 10 the switch
Re: STB`s Graphik LCD und Rumba? 22. August 2013 14:09 |
Re: STB`s Graphik LCD und Rumba? 28. August 2013 09:19 |
Registrierungsdatum: 13 Jahre zuvor Beiträge: 2.469 |
Re: STB`s Graphik LCD und Rumba? 28. August 2013 11:53 |
Registrierungsdatum: 12 Jahre zuvor Beiträge: 3 |
